Question about Stoves Premier 720DCa Dual Double Oven
Oven keeps re-igniting
Hi, My Stoves 720 GDO gas oven lights, and when it gets to temperature it cuts out and starts to re-ignite. This continues. The oven is only 18months old.
I recently cleaned the oven with a standard mr muscle oven cleaner. Could this have somehow damaged the oven?? - If so which parts are likely to cause the oven to keep cutting out?
Is it worth getting a STOVEs engineer out or go local, bare in mind we are cooking for xmas dinner?
Any help would be greatly appreciated.
SOURCE: hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Posted on Dec 30, 2008
  • 250 Answers
SOURCE: stoves 720ef fan oven cutting out
I confirm that you should get an oven thermometer as I did as my 720 wasn't behaving itself. Lakeland do one that works well and is not to expensive. I found that the fan oven was working ok but the top oven was way out, i.e. setting 160 on the dial produced 140 in the oven. The thermostat sensors for both ovens are located at the rear of each oven at the top right. They should be clear of all congealed fat etc and should be bright and silver in colour. If they are dirty this may cause them not to work correctly. Lakeland again do an oven cleaner that you paint on with a brush. It may take more than one go but it cetainly removes all the rubbish and may well restore the thermostat to near normal operation. When cleaning the sensors be careful of the thin wire from them as if this is damaged you will have to have a complete new thermostat.
(The oven cleaner works on everything inside the oven including the stay clean lining).
As a final thought is the cooling fan running when the oven fan is on as this may cause the oven to overheat?
Best of luck.
Posted on Jan 05, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Posted on Nov 19, 2010
  • 195 Answers
SOURCE: i have a stoves 700 GDO oven and it cuts out when has been on for a short while?
would inspeck useing a flash light ,,,the cal-rods for damage it will look like bubbles or bumps
Posted on Dec 17, 2011
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
Gs773lxss0 will not light
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Oct 21, 2013 | Whirlpool Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves Premier 720DCa Dual Double Oven Logo
55 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
