Question about EliteGroup ECS A780GM-M3 AM2+ AMD 780G Micro ATX AMD Motherboard
No monitor I've installed the motherboard have double checked all connections to it and all devices including I/O devices, but have no image on monitor to view to run set ups???
    Scholar:
  • 138 Answers
Try this, reset the CMOS, but make sure that the power if fully turned off and the power cable connected to the power supply is disconnected. Change the jumper settings of the clr_cmos from 1-2 to 2-3 for approx. 10 secs. then return the jumper to 1-2. the locations is encircled on the image below.no monitor - a55d1a2.jpg
Hope this helps.
Posted on Sep 26, 2009
Can't connect monitor to MA770-ES3 motherboard
The 9 pin port on the backplate of the mainboardc is NOT for monitor screen, but is a serial port.
You need a PCI-e Graphicscard to connect your monitor screen.
Be certain that the graphicscard does have a 15pin sub-D port.
Most newer cards do have DVI and HDMI, some also have 15 pin sub-D.
Oct 21, 2011 | Gigabyte Computers & Internet
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My advent pc which has a fox conn a7vmx k motherboard wont boot up, it powers on with constant fan only. I've removed and put back in each device one at a time but that failed too. Anyone know what I can...
Keep connected just the keyboard, mouse and monitor and try to boot in the BIOS - if it fails then the motherboard is faulty and you must replace it.
Dec 05, 2010 | Foxconn A7VMX-K Motherboard
I need Intel chipset 865 motherboard sound(audio) drivers for windows 7 ultimate 32bit O/S...
no sound driver is available for a 865 chipset for Win7...
check the intel site...
as an alternate the best option is to use the below shown...USB Sound Adaptor Card....buy it on Ebay for 1$...and connect the speakers and mic to that....it's the best alternate for the time...i too use that...as my MB is also a 865G....the sound is also great...no difference...
check this image
Nov 01, 2010 | Intel 865G Motherboard
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
The led is working the heatsink and fan is moving the monitor led indicator is turn-on but has no display
test your cpu on a different motherboard. it may be your problem. if not send the motherboard to warranty. the vga component may be broken
Nov 01, 2009 | Asrock P4I45GV R5 Motherboard
NO DVI or VGA SIGNAL to MONITOR
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 02, 2009 | ASUS K8N4-E Deluxe Motherboard
Help make speakers work
raggedyan184 -
You can find the driver for your monitor here:
http://www.howtodrivers.com/model501390.html
(You will have to enter in the numbers shown above the "Download" button in order to download, security measure for the site)
The following instructions (from the site) are also listed for installation:
Step-by-step guide for install HANNS.G HU171D driver.
1. Download file for HANNS.G HU171D from our site, save it on your computer and unzip.
2. Connect your HANNS.G HU171D to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new HANNS.G HU171D on Lcd monitors category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Hanns.gdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new HANNS.G HU171D in Lcd monitors inside device manager.
Hope this helps!
-- RT
PS - If this was useful, don't forget to vote!
Sep 08, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
"No scan options, refer to devise docs."
Hi
I have provided the troubleshooting doc, please follow this to resolve the issue.
Solution:
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 14, 2009 | HP OfficeJet J4580 All-In-One Laser...
I am trying to scan a pic and my scaner says no scan options
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Jul 08, 2008 | Office Equipment & Supplies
EliteGroup ECS A780GM-M3 AM2+ AMD 780G Micro ATX AMD Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
