Question about Inland ProSound 2000 Computer Speakers
No sound, computer says no sound device
There is no sound coming out of my speakers! i checked the computer and apparently there is "no audio device". i plugged it in and out, even in the back of the base. and nothing works. help!
    Guru:
  • 1,481 Answers
Hello....
No Sound, No Volume Control, Mixer not Found…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE..VERY..IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots...
all the best...
Posted on Dec 21, 2009
Not working
If you are usiing windows, should checl Cotrol Panel, audio and sound device and verify is sound is bot on 0%. also should check in Advanced Properties if speaker not silenced. Sometimes Windows silences ithe computer without any apparent reason. Steps might be slightly different, depending o version of Windows.
Missing or lost sound in Windows
https://support.microsoft.com/en-us/kb/272128
How do verify that sounds are playing properly on Windows 7 Vista
Windows XP Audio Settings
Sep 17, 2015 | Audio Players & Recorders
The speakers make hissing sounds but no audio comes out.
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 16, 2011 | Audio Players & Recorders
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
also
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
Our Compaq desktop computer has internal speakers. For some reason there is no playback sound coming from them though. We bought a new, green audio cord to connect to the CPU and monitor. This still...
Hello
Sounds like the drivers for your audio device are missing or corrupt.
Go to control panel/audio or sound devices and make sure your device is listed and checked to enable.
Next go to Hp compaq.com and find which sound device is in your pc.
Download and install drivers for sound.
Or if you have the cd or dvd that came with the pc the drivers should be on there.
Jan 08, 2011 | HP Compaq Computer Speakers
I cant get the sound to work on the computer. apparently the sound card is not working or installed properly
got to control panel then system open it go to hardware profile. look for sound card try to click update driver.
Dec 04, 2009 | Cars & Trucks
My computer doesn't recognize my Boston BA745 speakers!
look at
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
if its like that it should work. if it does not, test the sound out plugin for audio with some headphones... check that your master volume is un muted. check that plugins are inserted properly, if still no audio, click "start" right click "my computer" click "properties" click device manager"
and look at your audio area,,, if its all fine, no red or yellow little things beside your speakers.. your fine...
otherwise.. its probably a bad wire leading from computer to sub..
Jul 29, 2009 | Boston Acoustics BA745 Computer Speakers
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
No sound coming out of speaker
Please see that you have not muted the sound device;
First check whether your speakers are on monitor (builtin) Or System Builtin;
No got Control panel Select> Sound Speech and audio devices>Sound and audio devices>See the audio tab.
Else you may see in the device manager that you have installed drivers or no;
Mar 18, 2008 | Acer Aspire™ T180 PC Desktop
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Inland ProSound 2000 Computer Speakers Logo
162 people viewed this question
Top Inland Audio Players & Recorders Experts
Steven Burn
Steven Burn
David
David
Are you an Inland Audio Player and Recorder Expert? Answer questions, earn points and help others
