Question about Roper RAS8445KQ Top Load Washer
No spin on a roper
My roper will not spin. I have it opened up, but don't see a belt. What the heck do I do?
thanks, quinten
  • 3 more comments
  • Anonymous Jan 19, 2008
    does not spin all the water out
  • Anonymous Mar 12, 2008
    we have this model of Roper top load washer. It fills, washes, empties but doesn't spin. A couple of times we've been able to manually turn the barrel, then it will begin spinning. Now the barrel is VERY resistant to manual turning. And the spin cylce will then work but not at the correct speed. Do the bearings go out? What else could be the problem; we don't think its the lid switch, based on the resistance we feel and then sometimes it will spin. HELP I don't want to spend the bucks on a new washer!
  • peteA Mar 17, 2008
    My roper washing will spin but it leaves the clothes soaking wet. any ideas?
  • ashleyr Apr 10, 2008
    my washer files up but wont drain or spin? what is a matter? I can hear a noise like it wants to work but it don't do any thing
  • rugger2 Jan 08, 2009
    OK. My machine is dong ha same thing. It goes through the wash cycle mormally till it gets to the fianl spin. Then it either fails to spin at all or spins slowly which is ineffecive at removing water from the clothes. I have opened the lid, manually rotated the drim a revolution, closed the lid and the machine will spin but it is still at a slow speed. Does anyone have solution?
My top loading 14 year old Roper ,fills, agitates and empties but doesn't spin . I am thinking of a new machine but the door of the room it's in .has to be made wider for a newer machine ...so if it's a relatively simple repair will do it myself .Any ideas as to the remedy and is it worth it .Thank You Angelx
Posted on Mar 05, 2008
I looked for the lid switch before looking for the non-existent belt..banged it a couple of times and now its spinning...thank you...Marian
Posted on Feb 26, 2008
    Scholar:
  • 196 Answers
This machine does not use a belt. It has what is called a motor coupler between the motor and transmission. This is not the first place to check. I'd be looking at the lid switch first. This machine will not spin if the switch is faulty.
Posted on Jan 12, 2008
Burnt rubber smell during spin cycle
Assuming it's a top loader, the coupling between the motor and the tub is failing. If this is an older machine, the cost of replacement may not be within reason. The cabinet has to be removed and additional disassembly is required to replace the coupling
May 15, 2013 | Roper RTW4300SQ Top Load Washer
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
How to take back off of a roper washing machine
Your washer does not have a belt! It operates on a "direct drive" concept. You could have an issue with one of the following:
* spin/lid switch
* drive coupling assembly
* timer
* motor
Contact an appliance service company.
Feb 24, 2010 | Roper Washing Machines
The macine fills with water but when it is supposed to spin it barely moves. When you spin by hand it begins to spin on its own
it would appear that you have a poorly tentioned serpentine belt of the belt has snpped
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ0 spins but not fast enough
if it has no belt, seams like the clutch is slipping in the transmission, hence the burning smell
Jun 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
Roper Washer doesn't spin
If it is direct drive (no belt) it may be the motor coupling,
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper Model RAS6233KQ Spin Cycle doesn't get the water out
Its sounds like the pump has frozen, If your smelling the belt burning its either that, the tranny binding, Or the tensioner has a defect (very unlikely). If its washing, agitating and spinning okay its the pump. Get ya a new belt while your at it!
Oct 22, 2008 | Roper RAS6233KQ Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
93 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
