Question about Phones
The phone has switched from tone to pulse - Panasonic Cordless Model KX TC1405C
There is no button on the side how do I fix this?
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Posted on Dec 22, 2007
  • 3 Answers
SOURCE: Cordless telephone sw/from pulse to tone
In General Electric (GE):
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
  • 3267 Answers
SOURCE: english manual for Panasonic KX-TG1100CE cordless phone
You can downoad it from this link: or you can buy a copy from :
Posted on Jun 23, 2009
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
-Press "Program button"
-Press "AUTO" buttton (Just left to the "TALK ON/OFF")
-Press "*" two times
-Press "Program"
Along BEEP sound will come. That's all..!!
Posted on Feb 16, 2010
SOURCE: I have a panasonic KX-TGA101s
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
Posted on Jan 15, 2011
0 characters
1 Points
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
How to set name and contact number on the telephone set for one touch dialing with right buttons? My set is Panasonic KX-T7730
It depends on what happens when you dial "9" from the intercom. If it gives you a line, then that's your "access code". If it gives you a line that doesn't exist, then you need to fix your programming.
From the idle phone, press PROGRAM, one of the right side buttons, and dial 9 and your number and STORE. You can program one or all 12 buttons at once. When you're done, pick up the handset and drop it back down to exit programming.
That's it.
Feb 13, 2011 | Panasonic KX-T7730 Corded Phone
How do we set Personal speed dialling on KX-T7730?
Down the right side of the phone you have 12 Personal Feature buttons. Also, from the intercom, dial "9" and see if you get an outside line. If you don't, you need to fix that in system programming.
Now, from your phone, press PROGRAM, one of the 12 right side buttons, and dial "9" plus the number you want and STORE. You can continue programming all 12 buttons and when you're done, pick up the handset and drop it back down to exit programming.
You dial them by pressing speakerphone or picking up the handset and pressing the button.
Oct 20, 2010 | Panasonic KX-T7730 Corded Phone
On 2 of the 4 handsets on my Uniden DECT 2080, the large middle button has stopped functioning properly. It's the button with caller ID, phone book, and arrow buttons. One stopped working about 2 months...
After having the same trouble with my DCX200 and not finding a solution online for the problem, I set out to find a solution of my own. The fix I describe below is probably more of a band-aid than permanent fix but it appears to be working great. The problem, I believe, is caused by the metallic compound that the manufacturer used on the push button contacts in this model of phones and more specifically with the large multi-function button. This compound appears to wear off quite easily with repeated use of the keypad. Along with this I think that the design of the multi-function button did not take into consideration the environment in which it would be used. Not everyone washes their hands and face before using a phone (does anyone?) and between grease, make-up and natural oils of the skin building up and eventually making their way down into the components, this may be a contributor to why these buttons are so susceptible to failure.
_889.jpg What you will need:
1) Small Phillips head screw driver.
2) Small flat head screw driver (not shown).
3) Goo-Gone, Isopropyl Alcohol or some other degreaser/cleaner.
4) Hole punch, preferably smaller than a "standard" hole punch. I found the one I used in my wife's craft supplies.
5) Cotton swabs.
6) Metallic or foil tape. Can be found at any home improvement or hardware store.
Step 1. Remove battery and two screws circled in red with your small Phillips head screw driver.
Step 2. Pry off the dark grey back of the phone case with your flat head screw driver. I found that starting at the base of the phone and working around the sides was easiest.
Step 3. Being mindful the the wires that attach to speaker take the dark grey back off of the phone. Next remove the screw circled in red below:
Removing this screw will allow you to remove the circuit board from the front face of the phone to expose the numeric keypad as shown below. There is a thin white plastic keypad component that will either remain affixed to the keypad or the circuit board when you remove the circuit board from the front face of the phone. Be sure not to damage that.
Take the white plastic sheet and affix it to the circuit board side (if not already on it), with the small black button contact points facing down onto the circuit board as shown below:
Now soak one side of your cotton swab in your Goo-Gone or Alcohol solution and clean both the four small black push button contacts of the large multi-function button on the back side of the keypad and also the contact points on the circuit board. Then take the dry side of the cotton swab and remove any excess cleaner on the button contacts and the contact points. This step is critical. This cleans the surfaces and makes the push button contacts on the back side of the keypad ready to receive the foil tape.
Pictured below is the cleaning of the push button contacts of the multi-function button on the back side of the keypad:
Also clean the contact points on the circuit board using the white plastic sheet as a guide to where to clean. Don't forget to use the dry side of the swab to remove any excess cleaner:
Now the part that requires of bit of dexterity. Using your hole punch punch out four pieces of the foil tape. If you do not have a hole punch or are using a "standard" sized hole punch, you will want to try and use a scissors to cut out a small piece of foil tape that will fit over the black push button contacts of the multi-function key on the back side of the keypad:
Harvest the small circles of foil tape that the hole punch punched out of the foil tape.
You can see a couple of them on my finger below:
Now using your finger nail, gently remove the foil tape backing on these small circles. Yes, this can be a bit tricky, but I found it to be easier than I expected. With the backing off of the foil tape, affix your small foil circle onto the push button contacts of the multi-function button on backside of the keypad as shown below. Do not affix these to the circuit board contacts:
Do this for all four contacts of the multi-function button on the keypad. The picture below shows the finished repair to the push button contacts. I also placed the white plastic film component onto the keypad side to underscore the fact that you place the foil onto the keypad and NOT the circuit board:
Now place the circuit board back onto the front side of the phone (silver side) and fasten down with the screw you took out in step 3 above.
Affix the dark grey back of the phone onto the front side. There is a small plastic tongue at the top of the dark grey back that fits into a groove on the top of the front silver side of the phone. Get that tongue into place first then the rest of the back will snap into place.
After the back has been snapped back onto the front of the phone, fasten it down with the two screws you took out in step 1 in the battery compartment.
Put the battery back in, wait for the phone to turn on and try the keypad out. Below, you can see that I am checking the caller ID side of the mult-function button:
This fix appears to work quite well. I don't know how long the repair will last but it would be easy enough to do again if needed.
Sep 14, 2010 | Uniden DCX200 Digital Phone
The not in service message is given when there is no telephone attached to the intercom number your trying to call. I'd re-check the intercom number your calling, this can be done by using the button inquiry feature on the set your calling. At the set your calling, press feature *0, then press the intercom button on the lower right hand side of the set. The screen will display the intercom number of the set.
Sep 10, 2010 | NorStar M7324 Telephone
How do I program the speed dial buttons? thanks
A 7730 phone has 24 buttons. The left side buttons are CO buttons with lights, the right side are Personal Feature buttons. To program the buttons on the right side, you press PROGRAM, the button, and dial 9-and the number then STORE. The left side buttons require a "2" first.
Oct 22, 2009 | Panasonic KX-T7730 Corded Phone
i need a manual for a vista 200 to programme it and to clear stored info i bought it second hand
Dec 05, 2008 | Bell BE-412CID Corded Phone
Answering machine is flashing CL after I lost power
set the CLock by holding down the buttons on the side of the answering machine - top button for day, middle button for hour, bottom button for minute
Sep 25, 2008 | GE 25932 Cordless Phone
Do not disturb on phone is lit up
ON THE BASE, there is a button that says do not disturb on the lower right hand side on mine and I accidently hit it and turned it on!! I kept trying to fix it with the handset and the menu!! My husband suggested I look at the base and WAHLAH!!! I simply pushed the button and it worked!!!
I'm trilled ...cause I was so frustrated!!! So...there you go!!!
Jun 30, 2008 | GE 25932 Cordless Phone
Fix time
log in thru a telset and when the 4 lights light up on the right hand side of your phone hit the bottom right button till you get to time and date and you change there.
Mar 18, 2008 | NorStar T7316E Corded Phone
Phones Logo
Top Phones Experts
Are you a Phone Expert? Answer questions, earn points and help others
