Question about Haier BC50 Compact Refrigerator
Do you know what the blinking red and green lights are for on a bc-50a chefmate fridge
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
I have a Chefmate BC-87/H mini fridge and I lost my Manual and I need to know if #1 is coolest or #9
jeeze! none of these idots who replied are reading your question!!! I have the same issue not sure which is warmer and which is colder. in my full size fridge, 1 is warmer, and the higher numbers are colder. if you found the solution though- i would really appreciate it if you could let me know! my email is mike41062@gmail.com... i have been searching for the user manual online and cant find it anywhere. cant even find a website for chefmate!!!
Sep 21, 2010 | Refrigerators
Will not cool light does not come on when door is open Chefmate Model: BC-50A
unplug, take the back cover off.
Look at the circuit board.
at the top right of the board there is a fuse.
if it is blown, the frige is dead.
you will probily find that there is a brown burn mark
on the upper left side of the circuit board under an aluminum
heat sink. that electronic part probily overheated and blew up.
unless your electronics skils are up to it throw the frige away.
but if you are up to it unsolder it, bring it to frys electronics, and
get a new one. Good luck.
Aug 25, 2010 | Refrigerators
NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL# BC-50A SERIAL# 060511869
remove motor and use the numbers on motor for replacement most appliance, hvac,and electrical supply stores even online carry replacement
May 06, 2010 | U-Line 15R Compact Refrigerator
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
I need to find the manual to the Chefmate mini fridge BC-87/H
Hi, get me a model # and I can look this up for you and try ans assist you.
Thanks
Vic
May 17, 2009 | Refrigerators
Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Jan 03, 2008 | Refrigerators
Haier BC50 Compact Refrigerator Logo
120 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
