Sony VAIO  VGN-FE880E/H PC Notebook
Problem for Sony VAIO VGN-FE880E/H PC Notebook
How to reset BIOS password on VGN FE880E
By internet_use on Sep 26, 2009
End-user has locked the BIOS, and needs to reset it.
It there a jumper like on most desktop PC's?
Suggestions are appreciated.
Thank You.
Solution #1
posted on Sep 26, 2009
Somewhat Helpful)
parrotheadpc
Rank: Guru  Sony Computer Hardware  Expert
Rating: 89%, 626 votes
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO VGN-FE880E/H PC
Questions and Unsolved Problems for Sony VAIO VGN-FE880E/H PC
Do you recommend Sony VAIO VGN-FE880E/H PC Notebook?
Answer
Answer
intermitant wireless through lan card , card light on front goes off and on
Answer
I installed windows vista and now my motion eye does not work
Answer
i have the motion eye but i cant find out where to open it at
Answer
I down grade sony vaio from vista to xp and my webcame is not det
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
