Question about Intertherm Heating & Cooling
Icing up - Intertherm Heating & Cooling
    Top Expert:
  • 12,650 Answers
Coils dirty or filter needs changing not getting enough air across coil remove filter using spray bottle with a little bit of dish soap spray across coils to clean do not wipe coils very thin will bend if pushed against[make matters worst] turn on fan let cleaner drip down to drain replace firter and run unit-other problem fan speed -and or freon leak both which a tech would need to be called
Posted on Sep 27, 2009
Icemaker keeps sending out cubes after let go of switch. Had to lock it off. Now inside of freezer is icing up.
Please check if the freezer door gasket is sealed properly.
By switch do you mean the lever on the front of the door.
Check also the small door where the ice cubes go threw. Make sure it is closed.
Jul 07, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you fix icing sensor error (ER IS) on an LG lfx25974st Fridge?
My lg fridge keeps beeping saying the freezer temperature is fluctuating
Jan 20, 2015 | LG Refrigerators
Is there such a thing as a chocolate icing recipe? I have a sponge cake that needs something extra on the top.
Chocolate glaze icing is easy to make. Here's a recipe for a basic one http://www.bestrecipes.com.au/recipe/chocolate-glace-icing-L3717.html
Once you get the hang of it, you can start experimenting with other types of chocolate icings, butter creams etc. You can't go wrong with chocolate - it's all delicious.
Feb 25, 2013 | Cooking
Refrigerator get icy every 4 to 6 week
Since your symtom is general, I'll answer as such.
An air leak due to doors not sealing can cause general icing. A defrost cycle that is too long can cause icing in areas other than the evap. A defrost cycle that is too short can cause evap icing. Intermittent problem with the evap fan. Overloading the unit with too much product can restrict air flow and cause icing. Door not closing due to spring loaded door closing hinge not working correctly.
I'd start with some of these suggestions to see if we can get you in a direction.
Your freezer should be able to handle a minus 5 to 10 degrees, generally speaking.
Oct 05, 2010 | True Freezer TG2F-2S
My new Haier AC is icing up
it either needs a good cleaning on the coils and filter or it low on freon.
Jul 07, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Evaperator icing up. timer r/r 3 weeks ago for same reason by a refer tech. started icing again yesterday.
Then there are other reasons for the icing. The defrost heater is defective, defrost thermostat, loose connections to defrost heater or low on freon. If you have a multimeter or ohm meter we can check the electrical. Lack of freon shows as a few rows are freezing on the evaporator and the other rows show only moisture. Let me know, Thanks, Sea Breeze
Jun 17, 2009 | Refrigerators
Door gasket icing
Icing is caused by warm, moist air hitting cold air. Either your gasket is not properly sealing to the frame or the door frame heater is either off or not working. Some units have an off/on switch for that. The heater is usually referred to as an "Anti Sweat" heater. Make sure the door is closing and sealing. The door frame should be slightly warm to the touch. If not, look for no power to the heater or the heater could be damaged/ burned out.
Good luck and hope this helps,.
Mar 21, 2009 | Freezers
Chest type freezer icing up real bad
I quick way to test the door seal is take a dollar bill close the door on it if you can pull the dollar out with little resistance the seal needs to be replaced. That is what I am thinking is wrong with unit.
Dec 03, 2008 | Freezers
Bike loses power
and although it runs fine most of the time it has cut out 3 times for no apparent reason - it just loses power and then won't re-start for a few minutes. The only likely explanation seems to be carb icing - there's nothing obviously wrong with the bike otherwise. Someone told me 2 strokes don't get carb icing but that makes no sense to me. Can anyone tell me whether these bikes are prone to carb icing and if so what I can do about it?,carb icing is maybe a factor but i doubt it.ive worked on all kinda bikes for 20 years and have rebuilt a freecia last year.freccias are fickle fings so i would suggest that u make sure the fundementals are correct first.i,e float hieght, condition of carb and jets.check coorect grade of plug and ht lead & cap.cagiva do reccomend in cold weather to add a little two stroke oil in the fuel tank so this may suggest a link to carb icing.if the above checks out ok and u still have problems then it could be time to check electrical side of things.also and i know im going on like an old fart but is your piston \ bore ok.? realy advise you change piston evry 6k miles. ,,,
Nov 10, 2008 | 1990 Cagiva Freccia C 12 R
Dehumidifier
Check the coils for icing. You may need to remove a cover to see them. IF the temp is much below 65-70 degrees, there is a good chance of icing. Take it upstairs or where it is warm and try running it to see if it removes moisture. If it does, it is probably icing. Raise it off the floor as the temp is higher towards the ceiling. Hope this helps
Jun 26, 2008 | Dehumidifiers
Heating & Cooling Logo
49 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
