Question about Frigidaire FRS23R4A Side by Side Refrigerator
Rust under water dispenser on freezer door
Is it hard to replace the door and swap all controls over? has anyone else had this rust problem?
  • Mike Briley Jan 25, 2008
    I own the same Frigidaire "Classic" side by side painted "bisque" refridgerator (4 yrs old) and the rust beneath both lower corners of the Water / Ice dispensor is now so bad, it's lifting the paint. How does one fix the problem and stop the rusting? Shouldn't this be under warranty?
    Any help would be appreciated. Mike in S. Florida
I had the same problem and I replaced the door. I also found out that this problem is cause by water going into the two screws in the back of the Water/Ice dispenser. He is right; it was hard, but possible. Be careful when removing the Water/Ice dispenser.
Posted on Feb 19, 2008
  • georgekately Nov 18, 2010
    what happens if no one will let you get the door. that you have called the place were you have got it and they refuse to let you get the door and you just dont feel like wasting more money on another fridgerator when you just got this one like 3 years ago.
  • 89 Answers
Yes it is very hard to do. Its a bit easier with two people but still a pain in the but! goodluck....
Posted on Dec 17, 2007
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
We have the Kitchenaid Refridgerator Side by Side with ice and water dispenser. 4 of the wires at the bottom of the freezer door have been cut from use, therefore the ice and water dispenser will not...
you can join the spliced wires back together if they are long enough. try to extend the wires by a inch if you can. the harness is built into the freezer door. so you would actually have to replace the freezer door. Those are the only 2 options.
Jul 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
The water and ice dispenser stopped working, nothing on the control panel works at all
Looking over your wiring diagram I would go straight for the freezer door light switch. Part number 241547901 or 1037569 Switch-light lamp,freezer door. It is used as an interlock to disable the dispenser controls while the freezer door is open. I would unplug refrigerator and remove switch by prying out of its slot in the door frame. Use an ohm meter to test both ways. It has a three wire connection that while door is open lights are on and dispenser control disabled. When door shuts lights off and dispenser should have power. Let me know what you find, Thanks, Sea Breeze
Mar 19, 2010 | Frigidaire FRS3R5EMB Side by Side...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
May 26, 2009 | Refrigerators
Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 15, 2009 | Whirlpool ED5VHGXM Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
815 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
