Question about American Pro VS-1499 CD Player
Which wire do i connect the "pink" memory wire to on harness??
  • 54 Answers
All the time hot
Posted on Sep 27, 2009
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
According to most posts the pink wire directly connected to ECM would be the TACH relay to AutoMeter Tach Gauge. 2001 FLHR can anyone reassure me on this one? Thanks inadvance
http://www.officialharleyparts.com/harley/2001_all_flhr_i_ci_dom__and_int__models__ignition_circuit_sheet_1_of_2.jpg
Kind of hard to see in the above wiring diagram, but the OPTIONAL tach is a PINK wire that goes to an 8 pin connector.
Pin #3 is where it connects.
From there is goes to the ignition harness, if a carb model.
-OR- to the ECM harness if a FI model.
Feb 04, 2014 | 2001 Harley Davidson FLHR - FLHRCI Road...
What is the pink wire for in the stereo of a 2006 Hyundai Santa fe? and what do I connect the dimmer wirefrom the santa fe to in a new stereo
The pink wire from the stereo unit is often the dimmer wire, and is connected to a power feed from the vehicle's side lights. Not all stereos have a dimmer function however, and may not have this wire available.
Nov 04, 2012 | 2006 Hyundai Santa Fe
Where do i connect da pink wire
connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
May 13, 2010 | Audiovox VM9312 Car DVD Player
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
Oct 23, 2009 | JVC AM FM CD DET FACE CAR STEREO
Sound problems with installing radio in 2001 tahoe
There is 2 harness the one that you are usin wich is the main harness in the second one that normally is conected to power up tha casette deck,there it should be a pink wire conect this wire together with the red one located on the main harness,if you have any problem call me 830 488 2078 im in texas ask for Tony
Mar 13, 2009 | Car Audio & Video
Parking brake
If you have the VM9410 then there is a way to play dvd's even when you are driving. You must ground out the pink wire in the harness. This allows you to watch dvd's even when driving. good luck!
Feb 24, 2008 | Jensen VM9410 Car DVD Player
American Pro VS-1499 CD Player Logo
23 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
