Question about Panasonic KX TGA270S Cordless Expansion Handset
Accessory handset will not take a charge
Why will Accessory handset will not take a charge
  • 3 Answers
It probably needs a new battery.
Posted on Nov 20, 2009
Why do I see Base no power on display which also shows Charging?
Your phone is trying to connect via radio to a "base station". If you don't have one, your handset cannot work.
If you have a base station, your handset may need to be "registered" to it.
Apr 12, 2016 | Panasonic KX TGA680B DECT Accessory...
All of a sudden screen went blank charger is plugged in not charging.please help me
Most likely, your rechargeable battery went dead. Replace the battery, charge it fully overnight, and the phone should be fine again.
May 14, 2015 | Uniden DWX337 DECT 6.0 Waterproof...
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
I just bought another handset (DCX150) to use with my Uniden DECT1580 phone and cannot get it registered for use. The phone is completely charged but after holding down the # key for 30 seconds (as...
I had the same problem with the same equipment and I found this on the web. It worked well for me.
* Remove the base unit's phone from its cradle.
* Unplug the power from the base unit.
* press and hold the FIND button on the base unit, then, while continuing to hold down the FIND button, plug in power again. The CHARGE light should then be flashing. You can release the FIND button.
* press and hold the # (pound) key on the accessory phone you are attempting to register to the base unit and hold this phone OVER and NEAR the cradle/charging prongs until the phone goes through the registration process. (again, don't set the accessory phone in the unit, but just hold it near the unit).
Sep 11, 2010 | Uniden DCX150 1.9 GHz 1-Line Cordless...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
Apr 10, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
I have purchased two extra handset charger and accessory for a Uniden phone and when I set it on the unit it reads ---registering and after a moment it reads registration failed. I have two handset that...
Did you first charge the phone for at least 6 hours? Both the phone and the base need to communicate and if the hand sets are not charged they will not have enough juice to talk back. Hope this helps.
Sep 11, 2008 | Lands Phones
Panasonic KX TGA270S Cordless Expansion Handset Logo
119 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
