Question about Remington Factory Reconditioned 17-Inch 3.0 Amp AXCESS Electric Hedge Trimm
I was using it to trim a large shrub - then it just stopped working - I figured it was just too hot so I let it rest for a few minute s-then tried to get it going - no luck - I switch the cords and outlets to see if that was the issue - still no luck = does it have a fuse or a reset button?
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
How can I control fleas and ticks in my backyard? I'm scared to let my dog outside; we just got rid of his fleas.
Here is what you need to do: cut all tall grass, trim all bushes and shrubs and rake all leaves under your bushes. Look into buying a lawn insecticide and spray under shrubs, bushes and all shaded areas. Wait a considerable amount of time after spraying (up to 6 hours) before letting your dog play outside.
Aug 01, 2012 | Pets - Others
I HAVE A 1997 PLYMOUTH VOYAGER 3.0L ENGINE TURNS WHEN HOT AFTER 100 MILES THE ENGINE STALLS, IF I LEAVE THE REST RESTART IT BUT 30 MINUTES 15 MINUTES LATER HE HOLD AGAIN
Not clear on the issue. If the engine is stopping when hot, you will need to figure out if it is fuel or ignition related to proceed.
Jul 03, 2012 | 1997 Plymouth Grand Voyager
No water when valve is turned all the way to hot side
Remove the faucet handle and trim. Close of the check valve stops on each side of the valve body with a flat screwdriver. Remove the balancing spool and Moen cartridge. Look for and mineral buildup in side the faucet and on the spool or cartridge. If there is buildup on the spool and cartridge, place them in a large bowel with a cup of vinegar and a teaspoon of baking soda. The solution will remove the buildup in a few minutes. Replace the Moen faucet parts and test the faucet. If there is buildup inside the faucet body, use a wire copper fitting brush to the remove the minerals from inside the spool and cartridge tubes of the faucet body. Turn the stop valves on just a little to wash out the debris before reinstalling the spool and moen faucet cartridge. If the is is still no pressure on the one side or the other, turn off all the water to the house and remove the check valve stops, clean them as well and the inside of the faucet. If all else fails, replace the stops, spool and cartridge. Beyond that, the water supply lines may need to be flushes with the same solution.bbfb399.jpg
Oct 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Ive a s006 alloy shark remote controlled helicopter and i need to adjust it so it stops spining around but instructions arent clear
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Apr 28, 2010 | Head Cover For Syma Alloy Shark Rc...
WHEN I TURN ON THE CAMCORDER IT SAYS DEW
Hi, dew mean its the humidity sensor is on
thats lock all operation/ you can try an air dryer
:/open the loading tray if you can and blow at medium hot ,some hot air in slot for mechanism for few minutes avoid to be to close off the pastic cassing
and leave it rest for a few minutes and try it...
if wont work that is the dew sensor it self defect
hope that will help
Mar 29, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have an 04 f150. The drivers side window stopped working yesterday. I can hear the moter still working, so I think I just need to put the window back on track. what do I need to do to take the door panal...
Most likely the regulator broke. You will need to remove the door panel and replace the regulator after inspecting it. It is rare for the glass to seperate from the channel on this new of a vehicle. The directions for removing the door panel are too large for this forum. This is some basic info:
Remove speaker trim cover, remove speaker, remove door handle trim and 2 screws beneath the trim,pry up and remove switch bezel trim, remove bolt exposed after switch bezel trim is removed,remove 2 lower panel bolts. Lift up on panel to remove.Do not pull out or you will break the hooks!
Feb 27, 2010 | 2004 Ford F150
System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Apr 01, 2008 | Samsung HT-WX70 Theater System
Remington Factory Reconditioned  17-Inch 3.0 Amp AXCESS Electric Hedge Trimm Logo
328 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
