Question about Garden
My cat 301.5 has lost all hydraulic functions whilst in work . no oil leaks/hoses burst , no noise , not overheating.good hydraulic filter(recent)no fuses gone - any ideas?
  • 235 Answers
Check the armrest safety switch is engaged fully .Gets lose with wear.
Posted on Dec 31, 2009
My 2007 648h John Deere skidder makes a loud noise over 2000rpm as though its low on hydraulic oil which it isnt all functions work fine , any ideas
May be sucking air . Check all hoses and clamps between hydraulic tank and pump. Some models had a suction screen in hydraulic tank that when partially plugged will starve pump for oil.
Feb 18, 2017 | John Deere Garden
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
2000 crv honda just got a new timing belt and water pump after a couple of days now it make a noise (loud clicking noise) when I start it up
The noise you describe may be due to hydraulic tappet leak back form a oil that is of the incorrect viscosity or a cheap oil filter that doe's not have an anti leak back valve in it .The noise is until the oil pressure builds up and makes the hydraulic tappets work properly.
Jul 28, 2013 | 2000 Honda CR-V
98 Honda CRV power/overheating
If you are loosing coolant and cant find any leaks check your oil level. If oil level is rising.you have blown a head gasket or cracked a head. Common when an engine over heats badly.
Apr 23, 2013 | Honda CR-V Cars & Trucks
Oil coming from bottom of 1996 ford contour. No leak from the motor
If you have recently had your oil changed,the oil filter may be loose or cross threaded.Also if you have had an oil change recently it could just be spilled oil. Make sure your oil filler cap is on tight and the dipstick is on tight. While you are at it check to see how much oil you have actually lost.If it`s not coming from the engine,i would inspect the oil pan gasket and the oil pan itself may have a hole in it.
Nov 12, 2012 | 1996 Ford Contour
My recently purchased used MT180HD tractor will not move. I replaced all hydraulic oil,checked the clutch,and adjusted linkage. What next??? Are my hydraulic pumps bad?? Can a mechanical transmission be...
hi there joedorava
is there input to pumps , are there any leaks in the system either oil / air
have you purged all the air from the hydro units and wheel motors
if air is entraineed in oil , you may get alot of noise from caviatation in the pumps and wheel motors also heat , and vibration and no movement until all the air is gone
top up oil to correct level
caviatation can be quite destructive on pumps etc
i assume you used the correct hydraulic fluid for the unit in question
have you checked changed hydraulic filters when changed hydraulic fluid ?
other than that cant give any more info
cheers pauly46
May 25, 2011 | Diesel Compact Tractor 4x4 20hp Machine ...
1996 Motorguide Brute 765 problems with motor and clicking head coming out from head
sounds like a hydraulic tappet ,try my trick as sometimes it works ,firstly add a 3 good squirts of fairy liquid to engine oil and a half litre of diesel ,has to be fairy and not a cheap brand by the way .Then run engine for a couple of days and the noise will lessen,then change oil and oil filter and use a diesel engine oil suitable for turbo diesel or petrol engines ,cheapest you can buy for this no fancy long life oil ,run engine on this oil diesel oil as it contains detergent and this will dissolve the clag inside the engine and the hydraulic tappet ,change oil 5/6000 miles and by this time it should have lost the noise ,then change oil regular max 6000 miles with a oil filter every third oil change and you shouldnt have any more probl?ems
Mar 29, 2011 | Dodge 400 Cars & Trucks
Ram moves jerkily and then doesn't recoil
Check hydraulic fluid and ensure it is at the proper level - Still have the problem
Check hydraulic filter...may be clogged.
Check hoses and ensure there're no leaks.
Good Luck,
Mike...
Nov 22, 2009 | Kraft POW R KRAFT 65575 7 ton 2 Speed...
Car overheat frequently and at time the engine sound is very loud
Several things can cause this overheating. Have you recently done a:
1. Check Hoses for Leaks
2. Check Radiator for Leaks --- Also, Change Radiator Cap ( can loose pressure there if
cap is bad)
3. Check Water Pump for Leaks. If Water Pump is bad, you will hear a loud noise from it
4 Complete Tune Up? Should be done at least 1x a Yr. Depending on how much you drive the Vehicle. Includes: Plugs, Plug Wires, Gas Filter, Air Breather Filter, PCV Valve, Adjust Timing,
Check Belts -- see if worn
5. Changed your Thermostat & Gasket and have the correct degree Thermostat in the Vehicle?
6.. Had your Radiator Rod and Cleaned out?
7. Temperture Sending Unit (located near Thermostat) could be bad
8. 02-Sensor (Generally located in the Exhaust Manifold - needs a socket with a space in it
to allow the Socket to fit over this top wire of the 0-2 Sensor )
9. Change oil and oil Filter.
10. Change Gas Tank Cap ---
Do all this yearly ( except the Radiator Rod & Clean ( do every 2-3 yrs), and you should not have
any over-heating nor stalling out, etc. and should pass emissions as well.
Nov 25, 2008 | Hyundai Elantra Cars & Trucks
Overheating and now engine 'clicking noises.
possible causes of overheating are, dirty cooling system, clogged radiator, bad thermostat. Use only distilled water with a good quality coolant.
still overheating? have your top head checked - warped head, valves, valve seats, etc. You might need to have your engine's compression checked if it is still within specs.
Sep 24, 2008 | 1995 Jeep Cherokee
Garden Logo
571 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
