Question about Cell Phones
Both the outer and inner screens of my V9m are blank. I suspect that the ribbon cable got loose. The screens still become backlit when active -- but nothing appears on them.
5 Suggested Answers
  • 19 Answers
SOURCE: I replaced the outer and inner LCD display screens which are connected to each other. the outer display lights up but is upside down and is fixed on just saying verizon nothing else. Inner display is
Sounds like software issue not display, master reset!
Posted on Sep 20, 2008
  • 306 Answers
SOURCE: blank screen, very soft speaker
u first tak out ur battery for sometime and then replace it. there might be some problem in the battery. else u would have mistakenly put it down.. else u must contact a service center..
Posted on Oct 15, 2008
  • 7 Answers
SOURCE: why in thw world did my screens just stop working?
This EXACT same problem happened to me and I had to pay $50 to some cell-phone repair guy to replace the whole front piece of the phone....I HATE Kyocera and will NEVER buy ANYTHING from them ever again!
Posted on Oct 18, 2009
SOURCE: both screens of my EnV2 are blank but phone works
i am having the same exact problem HELPPP ! i need my pictures and contacts
Posted on Apr 01, 2010
Trottle cable on sthil 45z hedge trimmer too loose
The outer cable is probably not fixed in place at the bottom end. If so, instead of the control moving the inner cable and moving the air control butterfly, the outer cable is sliding down the inner cable and so no movement of the inner cable occurs. Look for a missing or loose outer cable clamp.
Jan 26, 2014 | Echo Garden
When slided in the display goes out... screen becomes blank and calles and messges cannot be seen
you have a defective flex cable or sometimes called ribbon cable, replacing it will fix the problem.
Oct 15, 2010 | Cell Phones
I have a motorola razr v2m, and both the outer screen and inner screen are blacked out. I can still make calls, if I know what number to put in, and I can still receive calls, but with out knowing who is...
Basically only your display is damaged/broke.So all your functions are working well.Please replace the display with the new one so that everything will be fine.
To replace please go to nearest motorola authorized service centre.They will replace the screen for you.
thank you
Aug 07, 2010 | Motorola Mobility RAZR2 V9m
The screen is all white
You need to re-seat replace the ribbon cable that is connecting screen to main board. Possibly out place after unit was dropped.
Sep 07, 2009 | Sony Ericsson K510i Cellular Phone
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Blank screen
You can open the camera and check to see if the LCD ribbon cable is still connected to the main board. If it was dropped they can become dislodged. There are two cables the smaller one is the most sensitive to coming loose. When disconnecting and reconnecting the ribbon cables, make sure you are careful while lifting the tabs that hold the ribbon cables in place they are hinged and will lift up and the ribbon cable will slide out. Note the large ribbon cable feeds through the camera to the front main board. Hope this helps
Apr 19, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
Display screen on DS Lite
I had this same problem on my Lite earlier this year.  It was still under warranty, so I sent it in to Nintendo repair, who replaced the hinge assembly.  Based on the symptom and the repair, I suspect it's caused by a loose/damaged ribbon cable between the upper screen and the rest of the Lite.
I'd be leery of trying to fix it yourself (I've worked on similar problems in laptops), but if your Lite is out of warranty, you might try one of the third-party repair services.  Depending on whether the ribbon cable is damaged or just loose, they may not even need any replacement parts.
Oct 14, 2007 | Nintendo DS Lite Console
Screen
Need more information.  Is it completely blank?  If so here is a solution.
Open camera then squeeze between your thumb and finger the cases
between camera lens and vol up/down buttons.  The ribbon cable located
in that area becomes loose.  By squeezing the cases together in that
area it reseats the cable.  Please let me know if this worked for you.
Oct 07, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
