Question about Mitsubishi WS-55819 55" Rear Projection Television
Picture is double and colors are out of focus looks like 3d without the glasses
  • 647 Answers
This is a common problem that would require 2 Convergence output IC's to fix . The part # STK392-560 replace with STK 392-570. a repair shop would charge between $200-$300 (parts cost $60.00)
Posted on Sep 26, 2009
  • 14 Answers
SOURCE: double picture
Call a technician to recalibrate your color guns. They usually need to be recalibrated yearly, lately. Many times the cost of getting it service exceeds the value of replacing it with a new one.
Posted on May 16, 2008
800pctechs
  • 39 Answers
SOURCE: picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Posted on Oct 02, 2008
SOURCE: PT4298HD Double image
my akai 42 inch 4298 hd television is showing double and tripple i tried to correct the problem by adjusting the convergence to no avail now the remote control will not work for the convergence and picture is distorted please help
Posted on Dec 30, 2008
  • 4234 Answers
SOURCE: Picture looks like 3D without the glasses
This is a convergence prioblem that can be as simple as poor solder connections at the convergence ICs or defective ICs. In any case, to provide details, I will need the model number. Can you please update this and confirm that the model number is: 60PP9202? ALso, please indicate whether or not you wish to attempt the repair and I will provide additional instructions as well.
Thanks,
Dan
Posted on Dec 18, 2009
welcomejee
  • 10594 Answers
SOURCE: color just went awry with a double image on
This kind of picture appears due to failure of two convergence output ICs in tv, replacement of these defective ICs will solve the problem and tv will start showing correct picture as it was before.
Soldering work is required to replace convergence output ICs so if you are handy with electronics stuff repair and can replace chips/ parts in circuit board then I can provide you more technical info.
Please confirm it is Sony KP-53HS30 tv or any other model?
Thanks.
Posted on Dec 17, 2010
I have a magnavox model #6p5440 w103. The picture is out of focus and looks like you're seeing doubles. Also the set 1 auxiliary a/v hook ups in the back work but show no color. Can you help me salvage...
if picture looks 3d with colors askew it is a convergence issue--set uses two chips, likely stk-392-120's and both would have to be replaced and set adjusted.
Mar 20, 2012 | Philips Televison & Video
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen is out of focus, the tv will come on but the picture is out of focus it looks like it is being stretched. Words are blury and faces are doubled.
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergnce ICS and some or all of it resistors to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Mitsubishi WS-65907 65" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Out of focus
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Mar 06, 2009 | Toshiba 56HM66 56" Projection HDTV
BINGO thats exactly what i get paid to do same price 285.00
Nov 30, 2008 | Akai PT4298HD Rear Projection Television
Picture in 3d without the 3d glasses
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double picture
May 16, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
