Question about JVC Televison & Video
Our 42" JVC plasma now has a black line right in the middle of the screen with some colored bard similar to performing a "defrag" on a PC. Is our set "shot?" it's only around 6-years old. Model # VM-42WV74 was fine 'til turned on around 2-weeks ago. Thanks in advance for any info...
I had the same problem with a JVC VM-42X795. The repair man said a wire in the monitor is probably borken that provides power for that enire row. I stared with one bad row, but ow I have two.
Posted on Jun 06, 2010
JVC 42 inch LCD TV model LT42X688. After TV has been turned on for 4-5 minutes different colored horizontal lines appear across entire area. Any suggestions?
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | JVC Televison & Video
Vertical Black Line
try wash out feture on samsung for 30 sec white out see what happends also upgrade your firmware for these via thumb drive ok
Feb 02, 2008 | JVC GD-V4211PCE 42 in. Plasma Television
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
I have a black vertical line in the middle of my
There are two boards at the bottom of the set connected to the panel. Follow the black line to the boards(it will be inline with one or the other) either that board is bad or the panel itself is bad . The boards do not meet exactly in the middle.
Oct 21, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Got black line in the middle of my 42 inch plasma screen
Perform the following tasks:
Determine if the "line" is an external cause or internal.
By external, it means a result of the interface, cabling or other boxes that are connected to the set.By internal, it means a defect within the hardware or software of the set itself.
Do find out you must disconnect everything but, say one video source. The best would be to unplug, pull everything from the back or front of the tv .By a process of elimination you should be able to convince yourself the source of the vertical line is external to the tv or internal to it.
Then, once you have decided that, you can attack the place that is most likely to be the source. For example, some of the early sets had some non-standard processors and had to be upgraged to the new standard after they were purchased by the consumer. It had to do with the HD and HDMI interface connections, but could have effected other stuff. Also, some S video inputs have glitches in them.
Aug 30, 2009 | Samsung PS42P2S 42 in. Plasma Television
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black line
Re-solder the 100 ohm resistors on the cables attached to the bottom of the display panel, each cable has 2 screws holding it in place. Inside the tv If you attempt to fix please do unplug the set. A resistor is a device with a wire out both ends and 100 ohm has the color code Brown Black Brown and then the color for tolerance
Jan 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
285 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
