Question about PfaFF Sewing Machines
Threading the pfaff 1229
Please show me the correct threading route for top thread of the pfaff synchrotronic1229. I've forgotten and there is no manual anymore.....Thanks
3 Suggested Answers
SOURCE: Bobbin thread bunching up.
You might have to adjust the tension. My machine was doing something similar because I accidentally changed the tension instead of the stitch length. The manuel should tell you how to adjust it.
Posted on May 10, 2010
hazelgrace
  • 340 Answers
SOURCE: My mother has a Pfaff
Hi
This site has instructions for a Pfaff 1221 and 1222.
http://www.sewingonline.co.uk/instructions/pfaff1222/
They might be similar to your machine?
Posted on Aug 23, 2010
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Apr 30, 2017 | PfaFF Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Tension on my Pfaff Grandquilter
check carefully that the top thread is actually gong between the tension plates and not behind them and jamming on the retainer bolt
before threading the needle place the thread up to the point of threading the needle and pull on the thread , proper tension is when there is a slight resistance to pulling the thread
If it takes excessive force to pull the thread then it is caught around something so follow the thread all the way back to the spool to see where the problem is
May 21, 2017 | PfaFF Convertible Sewing Machines
My mother has a Pfaff 1229 and has forgotten how to thread it. Please help.
Hi
Aug 11, 2010 | Sewing Machines
Sewing Machines Logo
110 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
