Question about Dell Dimension 2300 PC Desktop
Blank screen - won't boot!
I was suring the net on my Dell dimension 2300 when suddenly, the screen went blue then displayed a message about the system having communication problems with the keyboard... insert system disk and press enter. I had no system disk, so I hit enter and the system beeped several times, then shut down. Now, it won't boot. When I turn on the tower, it acts like it will boot up, but in a few moments, the greet power light fades out, however, the CD and DVD drive doors still open and close at the push of a button (so I think it still has power going to it). Also, when I turn the monitor power on, it comes on bright green for about 3 seconds, then goes orange and sounds like it is going into sleep or hibernation mode. The screen is totally blank. I put the diagnostic disk in the tower and it does nothing at all. I checked all the plugs and everything is snugly plugged in. HELP! Thanks... Karen
  • Anonymous Dec 26, 2007
    My hard drive is infected with viruses. Do I change/replace the entire drive or can it be cleaned (meaning wipe out all things on it) and redo it again?
  • Anonymous Apr 02, 2008
    I have checked the VGA adapter connection, i checked the pins on both ends of the monitor's data cable and they're all intact. I tried another using another monitor to ensure that the monitor is indeed faulty.
    while using a different monitor to go through windows, I changed all the setting on the power management options to never.
    Novelist:
  • 166 Answers
It sounds like you have either a failing power supply (can't supply enough voltage to run) or a failing motherboard. Open the case and look for swollen or bulging capacitors (caps). Caps should be perfectly flat and not bulging or swollen or leaking. Caps look like little cylinders, like tiny cola cans. DELL along with several other computer makers got a bad batch of semiconductors that would fail after awhile. Let us know what you find out.
Posted on Mar 09, 2009
    Problem Solver:
  • 5 Answers
Iv had this problem , you'll have to put the correct disc for the comptuer and start over again :) otherwise you mite aswell just throw your comptuer out.
Posted on Dec 17, 2007
  • Sarah harman
    Sarah harman Dec 17, 2007
    try you're local comptuer stores for the correct disc once you've got that try entering it and see what happens. keep proof of you acutally buying the disc as you can take it back to the store if the computer dose/doesn't work and get your money back. hope everything goes ok and : sorry for spammage :
Laptop goes blank on startup but still display logon screen
Have you upgraded the OS? At boot start tapping the F-2 key, do not wait for the Dell screen. Take a look at this forum:http://www.computing.net/answers/windows-95/dell-s-bios-startup-screen/85976.html
Nov 22, 2012 | Dell Inspiron Computers & Internet
I have a dell Dimension 2300 and the images are very dark. I don't think it is from the monitor.
Try these steps: 1. Check the monitor settings. Access the On Screen Display (OSD) Menu System. Adjust the contrast and brightness using the control buttons in the monitor.
2. Run the monitor self test. Unplug the video cable from the computer (cable from monitor to the back of the computer). Usually it has a blue or white connector. Turn on the monitor alone. It should display the self test pattern (white, red, green & blue). If the images are dark in the self test, it is a problem with the monitor.
2. Rotate the monitor to face a different direction. This will help in eliminating sunlight glare which can cause poor picture quality.
3. Test your computer using another working monitor. If the problem occurs in a known good monitor, then it is a video card or motherboard (if your video card is integrated) problem.
I hope these options help.
Jan 19, 2010 | Dell Dimension 2300 PC Desktop
GRAY SCREEN
go to this link for help on th codes. You might have the wrong type of memory or the memory could be bad or maybe it's not seated properly.
http://support.dell.com/support/edocs/systems/dim2300/advanced.htm
Apr 08, 2009 | Dell Dimension 2300 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Will not boot up
need help email me drummernick2002@aol.com live help thx nick
unplug any usb devise as u boot once
May 21, 2008 | Dell Dimension 2300 PC Desktop
Problem booting up dell dimension 2300 desktop.
You have no choice either you should reinstall your system, you should provide windows CD/DVD installation and boot your system using this disk.
However; you should backup your important files be cause most likely the all files will be removed during the installation process.
Jan 04, 2008 | Dell Dimension 2300 PC Desktop
DELL DIMENSION 8500
where do you see light?
I would check the power adapter with a multimeter first thing.
Nov 13, 2007 | Acer TravelMate 529ATX Notebook
ValuSoft's "Complete Bible Collection"
Have you tried to boot into Safe Mode? if you can do so successfully, you'll have a good chance of being able to undo some of the damage. Did you create a system restore point before the install?
Sep 28, 2006 | ValuSoft Bible Collection (10281) for PC
Dell Dimension 2300 PC Desktop Logo
151 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
