Question about Whirlpool LSB6200PQ Top Load Washer
Loose agitator Maytag LAT2600AAE
Seems like a lot of people are having problems with the loose agitators.  Same for me.  I can completely remove the agitator and I don't see any hole (s) for a set screw.
  • Susan P Feb 13, 2008
    I have the same problem with the agitator. This agitator has two parts. The bottom part which is attached by that 10 mm screw. Then the top part which slides down onto the agitator shaft that has the grooves that agitate the clothes. That has popped up and does not want to attach to the shaft of the agitator. There for the clothes are not getting clean. I do not see any screw that holds that part of the agitator to the rest of the agitator
  • jscamp Oct 07, 2008
    same problem
  • 196 Answers
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Posted on Jan 02, 2008
  • Farley9945 Oct 04, 2010
    It's not the agitator that's the problem. It's the auger that attaches to the agitator. The auger doesn't attach via a screw, it has teeth that locks into the agitator. After time the teeth wear out and there's no way to secure the auger. The solution is to replace the whole assembly, auger and agitator together.
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
Maytag washing machine, model LAT2600AAE, stopped draining water in spin cycle. The motor agitates cycle but will not drain water. What can I do? I'm not a pro at fixing these things.
On the underside of the machine, you'll see the belts from the motor to both the drum and the water pump. If the belt to the pump is intact, check to see if it is loose. If so, you'll see 3 screws holding the pump housing in place. Try to readjust the pump so the belt is a little more snug. This worked for mine that was having the same problem. You may need to remove the front panel to reach the drain hose to drain your drum 1st - have a couple buckets and towels handy as well as someone else to run and dump your full buckets. Good luck.
Mar 30, 2010 | Maytag Washing Machines
Agitator drive shaft pulls out of transmission LAT2600AAE
I believe there is a set screw or screw that goes throught the agitator to the shaft.
Mar 07, 2010 | Whirlpool LSB6200PQ Top Load Washer
Maytag LAT2600AAE with agitator that pulled out of transmission
You can find an exploded view at
Hopefully that will help.
Disassembly of washer agitator
With the palm of your hand, bang the very top section of the agitator, there are no screws, it is just a firm push-fit.
Do it with the agitator locked in the tub.
Oct 14, 2017 | Maytag Washing Machines
Washer will not agitate.
Pop the top cover on the agitator.
Remove the screw inside.
Remove the agitator and inspect it for damage where it attaches to the transmission shaft.
Feb 24, 2009 | Kenmore 23822 Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
I have a 5year Maytag washer,the agitator completely lifts out of the washer machine
May 29, 2008 | Maytag Washing Machines
Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Feb 09, 2008 | Washing Machines
Agitator loose
Just reach down between the basket and the agitator, and lift really hard straight up. Be sure not to hit yourself in the head when it pops loose. GE agitators just snap on to the air-bell underneith. Be sure that bell isnt loose after you remove. Good Luck!!!!
Feb 02, 2008 | GE Profile Prodigy WPSE4200A
Whirlpool LSB6200PQ Top Load Washer Logo
1,276 people viewed this question
Dan Webster
Dan Webster
Sal De
