Question about Yamaha YST-SW800 Subwoofer
Heelo, i have bought a onkyo 876 receiver to replace my old yamaha 757. my yamaha sw800 doesnt play any sound, the led goes green during films, but no sound. auto calibration doesn't recognize the sub. the cinch cable goes from sub out to mono in, as it was with the old receiver. i tried to change output level but it doesn't seem to do anything. here i am, thank you for helping if you can.
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
smarthome2
  • 1114 Answers
SOURCE: Home Theater Receiver keeps Shutting Down
Have you tried a different input on your TV? HDMI communicates both ways. You could have an issue with the input port on the TV. Try using Component. If you still have issues post a reply and we can dig further into it. Hope this helps
Posted on Jun 04, 2009
SOURCE: Ok- I need step by step, easy to understand
Hi brily, yes you need to conned another optical cables with your HDMI cables since in this model the HDMI is "switching" and the HDMI doesn't cary the sound ... I just bout home theater with this recievr model and I had to buy the extra optical cables to get the sound .
hope this answer your question .
Posted on Jan 06, 2010
  • 127 Answers
SOURCE: I own a Yamaha RX-V461 and since making a few
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Posted on Mar 02, 2010
TV programs filmed after sunset need to be brighter
Old technology. Clean the optics and replace the bulb. Better off buying a new LED flatscreen in 4K Ultra HD :>)
Mar 07, 2018 | Toshiba 56HM66 56" Projection HDTV
Green led light is on but no sound comes out
hello
check the leads from the source and to the sub.
use the remote to turn up the volume on sub.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Yamaha YST-SW800 Subwoofer
Onkyo 876 with hdmi from blu-ray sound is fantastic video poor
Get a THX video set up disk (some movies have them on) and read the Onkyo manual for video setup between source and target. I have the BD35 Blu ray and a Panasonc 37" plasma, the pic via the amp was a bit off before the 4 hours of tweaking but now looks fab, after the process tweaks the sound sync needed a bit of work to get it all synched up but it is really worth the effort.
May 19, 2009 | Onkyo TX-SR875 Receiver
Kube 2 subwoofer hum
The Kube Sub-woofer is earthed via its 3 pin plug. The Onkyo and other components I have in my system are not (they are double insulated). During normal operation, a difference in electrical potential can exist between these components in the system. I found that this potential was finding a path to earth via the audio cable and on through the subwoofer's earth. The path was via the earth portion of the audio cable and so gave the hum irrespective of volume levels set either on the Onkyo or the sub.
The fix is to ground the Onkyo to the sub. I used a length of electrical cable between a panel mounting screw on the back of the sub and a screw on the casing at the rear of the Onkyo. Try it out with a piece of cable manually touching screws with the bare ends of the cable until you find ones that give continuity( the hum will go immediately). I then crimped a small fork end electrical fitting onto each end of the cable which can be slid under the slighly loosened screw head and resecured. All I hear now is the fan on the Blu-Ray player!
Jan 31, 2009 | Onkyo TX-SR606 Receiver
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Audio problems
Hi, I just started having the same problems with my Onkyo TX-DS575. I have to play with the DSP buttons...the A/B speaker button...and now it has gotten to the point where my family and I lift the receiver up in the front, and slam it back down on the shelf and then hit the DSP buttons again and eventually we get some sound. This unit was already fixed once by Onkyo right after the 2 year warranty ran out for a similar problem. They returned it working...but scratched. This is the second Onkyo receiver that has died an early death within 15 years. I love Onkyo's styling, ease of use and sound, but I found the best way to solve this was by purchasing the Yamaha RX-V861 this week. I am done with Onkyo. Scotty D, Middletown, NJ
Aug 20, 2007 | Onkyo TX-DS575 Receiver
Yamaha YST-SW800 Subwoofer Logo
108 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
