Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
How to adjust chain bar oiler - Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
  • helfre Sep 27, 2009
    Stihl 026 is on the cover don't know the date
  • Daren Ingold
    Daren Ingold May 11, 2010
    Not all have adjustable oilers. What is the exact model number on the saw and what is its approximate age?
  • 148 Answers
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Posted on Sep 28, 2009
Testimonial: "Thank you very much for the info. I'll try it tomorrow, as it is now 11:50PM. "
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Feb 23, 2015 | Stihl GUIDE BAR 16 in STHIL CHAINS
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Auto oiler not working
Remove the bar cover. Remove the chain and bar. Behind the bar you will see a set of 4 or 5 small square openings. This is the auto oiler. Make sure they are not obstructed with gunk. There is also an adjustment to increase the oil flow to the bar. It is a small screw and will be marked with a + on one side and a - on the other. You can adjust it to run from 5 (minimum) to 15ml (maximum) per minute. Never use old motor oil or 2 cycle oil in yo
May 22, 2010 | Husqvarna Chain Saw 20" Bar
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
1,548 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
