Question about Sony Cyber-shot DSC-T10 Digital Camera
Sony DSC-T10 Cybershot vibration problem
When I slide down the lens cover there is a grinding noise and the screen vibrates. The pics come out blurred because of this. This does not happen when the camera is started in view mode but as soon as you go to shoot mode (slider over the screen at the back) it starts.
This problem started when the camera was only 2 weeks old and was accompanied by an error message (I think the message code meant: I have a problem but I dont kow what it is). When I decided to send it back it stopped happening, strange.
It started again a week ago (11 months later!) and now I cannot stop it.
Can anyone help Please?
£114 standard repair charge by Sony might as well buy a new one....
Thanks
Ken
  • 10 more comments
  • ChelseaFC Jan 18, 2008
    I am having the exact same problem. Other than in review mode, the camera vibrates violently (so much so that it is audible), and when I try to take any picture or video, it is blurry.
  • Anonymous Feb 27, 2008
    THE CAMERA VIBRATES IS SHOOT MODE
  • gilcaguicla Apr 18, 2008
    I've got the same problem. When in shoot or video mode it vibrates. Seems like a pager or a cellphone on vibra mode.
  • dt311 May 26, 2008
    I am having the same problem with my camera. When the camera is switched on, it vibrates. When I take a photo, it is blurry.
  • MikeJD May 31, 2008
    I also have the same problem - but not consistently. Sometimes I turn the camera on and off a few times and the vibration stops, but overall it seems to be getting worse. I think it must have something to do with the image stabilization feature. Has anyone figured out a solution?
  • ughboy Jun 12, 2008
    We're having the same problem and it's out of warranty (barely). Open the lens cover and more often than not it vibrates. Sometimes if you close it - the vibration goes away for a brief time. $141.00 to send it in? I'd rather put it toward a Canon.
  • Karipineni Aug 08, 2008
    Same problem, the rginding sound and pictures come out blurry........
  • taylorlovely Aug 13, 2008
    I'm having the same problem too. But if I stop and wait for the grinding/vibrating to stop then pictures come out clear.
    And there is no way I'm going to pay that much to get it fixed. I need a solution, bad.
  • prock80 Sep 21, 2008
    Same problem, vibration will stop and start in shoot mode.  It sometimes takes a long time but when it stops I can take pictures fine.  It can start up at any time while shooting.  I have tried diffrent image stablization settings but so far nothing helps.
  • jean-francoi Oct 13, 2008
    When I put the camera on , it starts to vibrate and it becomes impossible to take any picture or if I do it is all hazy . I push all buttons to try to stop this vibration and noise and one time time out of 5 it stops for a while and then it comes again .
  • Anonymous Feb 22, 2009
    probably dropped too many times (once!) and the steady shot motor is running in it's broken state. I have had this problem on ALL my DSCs (call it 7 since the dsc-t1) - they are extremely durable except this one component. The only problem is, you can't turn it off completely through the menus - it always wants to run. For a time I could get it t stop by turning it on and off a bunch of times and then maybe giving it a little tap with my finger/palm/hand/fist/hammer/1996 Suburban and so on. Now it runs all the time.
    I'm looking for maybe a service mode or debugging function if anyone knows of one.
    Otherwise just keep shaking it/cycling the power and you might have luck. Great cameras in all repsects except this...which is only a problem if you're not extra-careful with them - thing is, part of what makes these great is that you can take them anywhere and so you do...usually on some action-packed adventure.
    **** will get beat on a little when on an action-packed adventures.
  • waffleguy4 Mar 04, 2009
    Took the camera to the desert and probably got sand in it... same problem as above: screen blurry/unfocused when in capture mode and grinding sound heard when opening/closing shutter.
I just removed the cover off of mine. I wish I could have taken photos of what I did. The lens and focusing assembly can be flopped out after removing the 5 screws and cover. I disconnected the small flex cable that goes to the lower end of the focusing module (I think it is the motion stabilization module). I now get an error E:62:10 that continually flashes on the display on the back but the vibration that I had been experiencing since it was dropped onto a carpeted floor is gone and it takes pictures. I just completed this operation so I don't know if the other functions all still work as expected. I just hated the thought of throwing it away and buying a new one due to the expense of repair.
Posted on Mar 19, 2009
    Problem Solver:
  • 6 Answers
This problem is a known issue with this range of sony cameras there is an official fix which involves removing the stepping motor assembly and applying damping lubricate to the pivot points.
Posted on Mar 11, 2010
  • snowshooze Dec 22, 2010
    Do you have instructions to perform the repair? I have 3 cameras, two T-10's and one T-9
    snowshooze@yahoo.com
I have the same problem with my Sony T-10. I brought it to a Laker game and it started vibrating in shoot mode. I think because it was so loud during the game when I did try to take a picture, it came out blurry. I shook it a couple of times and it went back to normal. I tried to take a picture in the car and at home, no vibration. I tried it in a night club, where it was loud...and the vibration came back.
There is a sensor in the camera that cannot focus on shooting under loud environment. I took the camera back to best buy for repair...and they said they have heard of such a problem. This is an internal damage inside that needs repair.
Posted on Nov 09, 2008
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 74 Answers
Hello, If the error message you got is indeed E:62:10 or E:62:20 as indicated below (and it most probably was as seen the symptoms you describe), you can find the official list of error codes at https://www.sony.com.au/electronics/support/articles/00008857 : these are very well known and recurring problems with a lot of Sony camera's and indicates failure of the stabilizer. I found more than 300 forums discussing the problem, please read http://sony-e-62-10.tk/. A temporary solution is available on https://www.youtube.com/watch?v=S53D3EfDVk0. Hope this helps.
Posted on Jan 27, 2019
I have Sony T-200 for more than 2yrs. It has been working alright. Now when it is switched on it vibrates and the picture you get is out of focus?There is no vibration when viewing pictures.
hi, your camera has IS unit get defective cause vibrate noise. and out of focus. It will require realignment or lens unit assemble or replacement of the lens unit. your local repair shop would charge around $65 to 135 depend on what they really want to charge. Good luck with you and best regard!
May 22, 2011 | Sony Cybershot DSC-T200 Digital Camera
Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
May 16, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
My Sony camera vibrates when switched on and will not take pictures anymore. It is a cyber-shot DSC-T20
There is a known issue (vibration) with the DSC-T20 Cameras.
DSC-T20 Cyber-shot Camera Vibration:
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
Good Luck!!!!!!!!!!
Oct 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
My touch screen is broken on my Cybershot DSC-T50
do you still have that camera?
I broke the lens on mine but everything else is working, could we make an arrangement?
Sep 04, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
It happens when you open the lens
Hi!
It's a stabilized problem - happens to these cameras. You should contact your local Sony service center and ask how much will cost lens replacement. If they ask too much, you can contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 20, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot DSC-T10 - Silver (7.2MP, 3x Optical Zoom) 2.5" LCD. When the camera is turned on the screen is white. There is also a black swirl through the centre of the screen, the shadow of this...
I have lost my battery cover for my Sony Cybershot DSC-T10. IF your camera is water damaged and you want to sell it. Let me know, I could use the battery cover that slides and "clicks" into place.
Thx
Mark
512 784-6771
Sep 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Broken LCD Screen on Sony Cybershot DSC-T10
Hi there, I now have two Cybershot DSC-T10 with broken LCD's. The best remedy that I have found is buy a parts camera with a good LCD on EBAY. You can get the whole camera for way cheaper than you can buy a new LCD.
Mar 25, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot  DSC-T10 Digital Camera Logo
2,014 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
