Question about Casio EXILIM EX-FC100 Digital Camera
Recording video on high-speed
When im recording video on high-speed, the good clarity and light are gone. Video is dark. whats problem..its normal?
4 Suggested Answers
SOURCE: dark lcd and ddark video
need instructions how to use dvr-310 vivitar
Posted on Jun 17, 2008
  • 80 Answers
SOURCE: video records at high speed
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
Posted on Aug 28, 2009
  • 11967 Answers
SOURCE: when i use the video setting on High Speed, the
Think about it...when on high speed, the shutter isn't open as long as when on "normal", therefore, less light hits the sensor. You could try raising the ISO setting or raising the exposure compensation setting for more light.
Posted on Dec 10, 2009
Can dvd flick be set for a 16:9 aspect ratio? I don't see anything there. What is the recommended burn speed to get a clear dvd? What file type imported gives the clearest final burned dvd?
Aspect ratio is determined by the actual recording itself and that is based on whatever aspect ratio the file was recorded at. Players can change that ration on replay, but it will result in distorted images.
Burn speed has nothing to do with video clarity. The only reason to burn a DVD at any speed slower than its rated maximum is if you are having issues with validation of the burned media. If that occurs, a slower burn rate is recommended.
The file type is normally irrelevant. What really matters is the file content. What is the resolution of the recorded image? If it is only 480i, then you will have a poor clarity of video regardless of the file type. If you have 1080p video, you will have much greater clarity. Also, the amount of compression matters since over-compression of files, while reducing file size, will result in poorer video quality even at higher resolutions.
So, regardless of the file type, ensure that the resolution is high and the video compression is as little as possible to ensure best result.
Sep 28, 2015 | Computers & Internet
Night vision camera dark
IF VIDEO WAS OK AT SOME PONT IN PAST, THEN CAMMERA BUILT IN ILLUMINATOR HAS GONE BAD (LIGHT BULBS BURN OUT YA KNOW)
IF VIDEO WAS NEVER GOOD FROM START YOU HAVE ASKED TOO SMALL A ILUMINATOR TO ILUMINATE TOO LARGE AN AREA , ADD MORE ILUMINATION TO AREA OR REDUCE OBJECT RANGE THAT CAMMERA TRIES TO SEE
Feb 25, 2014 | Lorex 4 Channel Business & Home Security...
My webcam is not clear
Whether your holding a video business conference, having a personal video chat with a friend or recording video with your laptop webcam, image clarity plays a huge factor in the quality of the video.
There are a number of factors that contribute to the image quality, including available lighting and screen resolution settings.
Adjust your webcam settings, such as brightness contrast, hue and saturation to accommodate the lighting in the room. In order to access your webcam settings, click on "Start" and open the "Control Panel."
Choose "Hardware" and then choose your internal webcam from the hardware menu.
Select the "Properties" tab to open the setting controls and slide each bar until you achieve the ideal visual settings for your broadcast.
Increase the available lighting behind you when conducting a webcam chat, but do not increase the lighting close to the webcam.
A lack of back lighting not only creates a darker image projection, but can cause graininess. Too much light close to the webcam can blanch the image, making it difficult to see.
Adjust your screen resolution.
When the image quality is blurred and distorted during a webcam broadcast, lowering your resolution can sharpen the image projection.
To lower your resolution, right-click on your desktop and click "Properties." Choose "Screen Resolution," from the available prompts.
Lower the screen resolution one step below where it is currently set and test the image quality.
If it needs further sharpening, repeat the process until you achieve the desired clarity.
Adjust settings in the video chat program you are using.
For example, if you are using Skype, select "Tools" and click on the "Video" icon in the left toolbar.
Select "Webcam Settings" and adjust your visual and camera function settings, such as the hue and saturation, as well as lighting compensation.
Test your bandwidth settings.
If the traffic on your network is high, and multiple users are sharing the same Internet connection, it can affect your bandwidth and lower the quality of your video projection.
In order to conduct a quality video session, you should have minimum bandwidth connection of 128 kbps.
To check your bandwidth, visit an online test site like SpeedTest and run a bandwidth check.
Dust off the lens to free dust particles with an air can.
Dust particles can cloud the clarity, but you don't want to wipe them away with your fingers or a rough cloth.
Blasting the lens with a burst of canned air will blow away debris and help improve picture clarity.
Hope this helps
Nov 05, 2012 | Computers & Internet
Hi. While shooting a video, the recording is too dark even in normal light. Is there is mode or setting which can enhance the lighting.
Please check and adjust your white balance in sub menu. You can use trial and error method to get the best video appearance and delete the bad videos from camera memory.
Dec 22, 2010 | Sanyo VPC-CG10 High Definition Camcorder
Why dose my Lg KU990i high speed camera go very dark when im trying to rec video in high speed??
Probably because the frame exposure time is much shorter so it can''t expose the CCD as long.
Try processing the video with software to lighten after capture.
Dec 28, 2009 | LG KU990 Viewty
When i use the video setting on High Speed, the background is dark unlike the normal setting where the background is normal
Dec 10, 2009 | Casio Exilim EX-S500 Digital Camera
Video records at high speed
Aug 07, 2009 | Canon PowerShot G9 Digital Camera
Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Video recording
ya definitely you can record the videos from your webcam ,but with less clarity or frames per second,,,,,,,
Oct 25, 2007 | Logitech QuickCam Messenger Web Camera
Video and still image - SD Memory Cards
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Aug 31, 2005 | Panasonic D-Snap SV-AS3 Digital Camera
Casio EXILIM EX-FC100 Digital Camera Logo
18 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
