Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice melts, then refreezes. Rubber Is HOT
The ice maker works, but then the ice melts and refreezes into a solid block. The divider wall between the freezer and the refrig is hot, not just warm. It is HOT.
  • GE Master
  • 1,606 Answers
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
Posted on Sep 27, 2009
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
Freezer won't drain
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
May 11, 2012 | Whirlpool Refrigerators
Ice in bottom of maytag mfi2269veq1
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
May 08, 2012 | Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Marine ice maker problem
Mine has been doing this for years. You can check if the door gasket is good and sealing well. If not you can oder one and easily replace it yourself. Also, if I did not run my generator when I took a short ride ice inside would start to melt while the unit is off, usually around the case perimeter which would drip down to the bottom under the bucket and then when it was put back on it would refreeze under the bucket like a block and make it impossible to remove. I would sometimes just turn it off, put the ice in a ziplock in my frezzer to save it, let it defrost to get the bucket out and dry up the standing water.
Aug 25, 2007 | U-Line Icemaker
GE (PSS26MSRSS) Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
