I have a bosch classic electronic, the check water light came on mid cycle there was dirty water in the bottom of the machine, it wouldnt drain away. I took all the filters out, washed them, couldnt see a blockage , turned it on and of and reset several times, waited overnight did it all again. Nothing worked. So I just took all the water out the front so it was nearly all gone then I turned it on again and now it seams to be working, I'm going to get one of those finish cleaner bottles and run that thru now, I dont know what or how it all happened but it seams to be fixed now good luck
Check the entire length of the drain hose from the washer bottom to the connection at the sink drain for kinks--you may need to pull the machine out of the cabinet part way to check. Make sure the hose passes over a point higher than the drain connection at the sink. If you have access to a wet/dry shop vacuum, remove the sink end and **** the water out. If nothing comes out, then there is an obstruction somewhere. Use the vacuum to **** the drain opening inside the washer.
