Question about Danby DHCC6020 Dehumidifier
Danby DHCC6020 Dehumidifier; icing up on the lower vents after a few hours operation. Unit is just over a year old, and this just started happening. Haven't changed usage habits with unit.
  • Danby Master
  • 43,501 Answers
The unit is leaking freon...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 30, 2010
We have a DAnby dehumidifier - model SHCC6026. It keeps showing an E7 error. Is there a simple solution to the problem?
The E7 Error Code, indicates that the front cover of the unit it no properly in place and making contact with it's removal sensors. Remove and reinstall front cover properly. Be sure to turn the Master ON/OFF Switch to OFF and unplug unit before attempting this.
Hope this helped you solve the problem.
Jun 22, 2011 | Danby DHCC6020 Dehumidifier
I have a danby ddr586r dehumidifier. the coils are icing up. the outside of the unit also has ice build-up on the left hand side.
heatman101
May 30, 2011 | Danby DDR586R Dehumidifier
Danby dehumidifier ddr4588ee ices up. Humidifier located in basement with temp around 60degrees. Unit is 1 1/2 years old.
According to your Owners Manual, the coils may start to frost at 60 degrees and the defrost sensor should turn ON and cycle periodically. However, the air temperature at the floor level in a basement, is colder than the air temperature by 5 to 8 degrees. So this may be causing the problem. In addition, if the air intake filter is dirty or clogged, the unit has to strain to keep up and will not function as it should.
If the unit is totally iced up, turn the unit Off and unplug it from the wall outlet. Allow is to thaw completely before attempting to clean the filter. You may want to put some old towels under it while it thaws. Once it's thawed, move it to a bathroom that has a shower. Plug it it in and set the humidity level at 45%. Turn the shower ON at a Medium hot temperature (enough to generate steam) and as you exit the batroom, close the door. DO NOT operate the bathroom's exhaust fan. Allow the unit to operate for 15 to 20 minutes, before returning to the bathroom. Then turn the shower OFF and check the unit for any frost and the amount of water collected in the bucket. If there is no frost on the unit and there's water in the bucket the unit is operating properly.
When you move it back to the basement, place it up off the floor on something sturdy, that can hold the weight and not be bothered by the vibration of the unit, when it's running. (ie a work bench, a counter top, etc.) Operate the unit as you normally do and monitor it for frost or icing up. And, whether or not the defrost sensor is cycling as it should. If you get no frost or just minor frost, it was the air temperature at the floor level, that was causing the problem.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Danby DDR4588EE Dehumidifier
Unit is not collection water is bucket..
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 14, 2011 | Danby DHCC6020 Dehumidifier
Although it is plugged into a power source, the dehumidifier does not run. I need how to get it going and how to interpret the signals it gives me. marilyndufresne@rogers.com
heatman101
Feb 23, 2011 | Danby DHCC6020 Dehumidifier
A large block of ice formed over the entire front where the vent is. Basement temp was apprx 64 degrees F, but this model is supposed to operate at lower temps. Discovered after it was running continuously...
35 is way low; why not 50%?
At the cooler temp you may need to also run a small fan or space heater blowing on it.
It is working, but the setting is too low and the temp in the room is too low
Nov 25, 2009 | LG LHD65EBL Dehumidifier
Ice build-up on Danby Dehumidifier DDR583R
Make sure you have enough air moving over the coils. There is an air filter on some models which may be obstructed. Insufficient air flow will cause your problem.
Sep 17, 2009 | Danby DDR583R Dehumidifier
E3 error code on danby dhcc6020, its new out of box. tried danby service rep. , cant get a response back from them. any ideas on how to fix?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I had called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Danby Service Rep. helped me with my question about my P1 code (for DDR657EE).
Apr 11, 2009 | Danby DHCC6020 Dehumidifier
Danby DHCC6020 Dehumidifier Logo
269 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
