Question about Refrigerators
Hello. I have a Whirlpool Arco 500 refrigerator. I have no manual with it. Does it have automatic defrosting?
huuum
  • 750 Answers
SOURCE: semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
daddy1264
  • 76 Answers
SOURCE: i have a side-by-side refrigerator-freezer
that can be caused by a bad timer, bad defrost thermostat, or a bad heater
Posted on Jan 03, 2009
aasc
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
  • 2122 Answers
SOURCE: refrigerator keeps defrosting and depositing water in fridge.
if your food is staying cold your fridge is working fine,you probably have a blocked drain.you will find water under criper draws and maybe leaking out on floor,take off the back freezer wall and take out floor, melt out the drain and remove all the ice on freezer floor,now you have to clean out the drain,i use a steamer that you can buy for like 40 bucks,it's a shark super steamer,it will clean out all the slime that builds up in the drain line or you have to snake out the drain line with a plastic tie or something,when you think you cleaned out the line pour hot water into the drain and if the water goes down you know you unclogged it,you can buy a heater probe that installs down the drain and wraps around the heater so the line can't freeze up again,if this is not your problem you can advance the timer in the fridge side on the ceiling by turning it with a screw driver until it comes out of defrost and if it was sticking or not coming out of defrost on it's own change the timer the new part number for your timer is 2183400 hope this helps
Posted on Nov 24, 2009
oldTech2332
  • 2341 Answers
SOURCE: I have a whirlpool refrigerator
That is going to be a problem with one of the components in the automatic defrost system. It is supposed to automatically defrost. Turning it off overnight to melt it will defiently help. If you are mechinacally inclined here is what to check.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
Posted on Aug 13, 2011
Why does my whirlpool ET25DQ refrigerator leak water?
If your refrigerator has automatic defrost, the defrost water should drain from the bottom rear of the interior into a drain pan underneath. The pan may be missing or damaged or something could be preventing the defrost water from draining into the pan
Aug 05, 2013 | Whirlpool Refrigerators
My refrigerator stopped working. I manually advanced the defrost timer, then it works for a few days but then stops working. I replaced the defrost timer, but it's still doing the same thing. What...
Their are going to two possible other parts that is not allowing it to defrost automatically they are either the defrost heater or termination thermostat for the defrost.This tip i wrote explains how to check those http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
It also says to check teh defrost control...in your case the timer so skip that part.
GENE
Sep 19, 2011 | Whirlpool Refrigerators
Frost build up in freezer
Probably a defrost problem no doubt. Remove the access cover and look for ice.themobilian_2205.jpg
If yours is an older model which has a mechanical timer what you do first is find the timer and try advancing it manually.themobilian_2206.jpg If it kicks into the defrost cycle then it could just be hung up. If by manually advancing it to defrost you don't see or hear any signs of any defrosting going on then maybe the heater or the heater thermostat has failed. If yours is a newer model which features automatic defrost you can check the heater and the termination thermostat and force defrost from the board or cold control.
Service manuals
More service manuals
over 500 more here
Apr 17, 2011 | Refrigerators
Freezer is too cold and icing over into the refrigerator - also makes a noise when the door is open and then shut. Refrig is not staying cold at all. HELP
It sounds like your automatic defrost cycle on your refrigerator is not working.
Try manually defrosting the fridge.
If this works then you will need to get the auto defrost repaired.
Mar 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Estate by Whirlpool freezer coils freeze up and both the freezer and lower compartments won't stay cold. I can manually thaw the freezer and it works ok for a few days then does it again
You have a problem with the automatic defrost cycle, it is typically the defrost control, which is located in the compartment next to the thermostat or cold control. If you send me your entire model number from the tag on the inside I can get you the part number needed.
Jun 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Semi automatic defrost button won't pop up
This happens a lot
Huum
This is the answer.
click solve please1
Dec 09, 2008 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
