Question about Canon PIXMA MP130 All-In-One InkJet Printer
I can not download a printer driver over 128 charcters
I can not download a printer driver over 128 characters in length. Why?
2 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: NOt able to download driver from Canon for mp780 printer
Try getting it from the Australian Canon page, the URL is shorter:
http://support-au.canon.com.au/contents/AU/EN/0100127601.html
Hope this helps
Chris (ziraffa)
Posted on Jan 17, 2009
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
Tip
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.0.1
2. You will need to log in to the router. The Default Username and Password:
User Login
Username: cusadmin.
Password: password
3. Next click on [WIRELESS] link on the Side Navigation bar.
4. Select [WEP] from the [SecurityMode] drop-down menu.
You can choose between standard 64-bit or 12b-bit encryption keys. Below are the configuration options for 64-bit WEP. A passphrase or a manual key can be used
NOTE: To enter a manual WEP key you will need to enter hexadecimal values (A-F and 0-9). Example: 64-bit hexadecimal keys are exactly 10 characters in length. (123654ACDE is a valid strong of 10 characters for 64-bit encryption).
To automatically generate a 64-bit WEP key, enter in a Passphrase (keyword- ex. homegateway). And click the [Generate Keys] option. Once you do this, the Gateway will dynamically generate 4 keys. Simply configure the Default Key to the one key that you will be using across your network.
5. Select the Open System, Shared Key or Automatic from the [Authentication] drop-down menu. Note in most cases you want it set to Automatic.
For more security, you can use 128-bit WEP encryption. To use this mode, select the [128 bit (26 hex digits)] from theWEP Key Length drop-down menu option and the configuration section will be displayed. 128-bit encryption requires a longer key than 64-bit encryption. Keys are defined by entering in a strong in HEX (hexadecimal- using characters 0-9, A-F) or ASCII (American Standard Code for Information Interchange – alphanumeric characters) format. ASCII format is provided so you can enter a string that is easier to remember. The ASCII string is converted to HEX for use over the network. You can manually enter in the 26-digit hexadecimal key.
Example: 128-bit hexadecimal keys are exactly 26 characters in length. ( 234FEDCBA12340013333389319 is a valid string of 26 characters for 128-bit encryption).
NOTE: If you are having a difficult time getting the wireless connection up after enabling WEP- Please confirm that you have configured the SAME WEP key on both the Gateway and Client card.
6. Click the [Apply] button to save your settings
on Feb 26, 2010 | Computers & Internet
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
HOW TO CHANGE SSID
Nov 08, 2010 | 2wire (1000-000057-000) Modem
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
I downloaded Windows 7 and my wireless laptop won't connect to my 2wire. Where can I get new security key code or info get my laptop to work?
Hey pkkern,
Your default 10 digit security is located on the bottom of your router.
If you want to change it or for some reason your default key is no longer working we will have to get into the routers configuration homepage.
To access this open up your Internet browser and write in this address, (which is your routers address) 192.168.1.254.
If your routers homepage does NOT open up check to make sure you have no software firewalls
You will see a wireless network security section, use the following information to select a custom wep-key.
Change your wireless settings and use the following information if you want to change to a custom WEP key. 64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
Thanks for using fixya!
If you need information just comment in this thread and I will get back to you, don't forget to leave feedback!
Cheers,
Jul 24, 2010 | 2wire (1000-400108-001) Router
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Ok no problem you can change the name and still download it. When you find the driver and are ready to download click "Save As" as opposed to Save or Open. A window will open and the second to last line on the bottom you can type in the name you want to save it as. MyDriverForSound for example. Then once the file is finished downloading just click "Open". That will open the file and install the driver, the computer does not care what the name is, the last three letters which are automatically assigned tells your computer it is a driver. If you have any questions let me know.
Don't forget to rate this 4 stars before logging out.
Jan 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi. 25 character product key for microsoft office home and student edition.............I need it?
I HAVE JUST FOUND MY PRODUCT KEY WITH 25 CHRCTERS IT IS UNDER MY LAPTOP, THERE IS A STIKER WITH 25 CHARCTERS AND THERE IS A DASH ( - ) BETWEEN EACH 5 CHARCTERS
THE CHRCTERS ARE NUMBERS AND LETTERS
Jun 23, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Horzontally double printing & characters are not clers.
Is the ribbon tight or sticking, If ribbon can't turn, it delays entire carriage, you will notice that if you move carriage up and down by hand ribbon turns, I have seen sticky ribbon s cause problems as well as gearing that drives ribbon with wornout gears
If self test fails then all faults /i can think of on these is
  • Dry rail/dirty bearing
  • incorrectly manufactured ribbon
  • Damaged dot head
  • broken/breaking ribbon interface carriage cable
  • worn ribbon drive gears
  • worn/dirty ribbon drive rail
  • main board
Nov 17, 2007 | Epson LX-300 Matrix Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
