Question about Nikon D80 Digital Camera
My camera will not auto focus properly...It will focus and refocus. I have to use the manual focus in order to use it.. I have already checked it was in AF setting both on the camera and the actual lens. I set my camera options to single focus. So what else may be the problem?
    President:
  • 423 Answers
Try removing any filters, if you have any on the lens. Check the front and rear lens elements for dust/fingerprints and clean if necessary. Check the mirror (remove lens and take a look) and very carefully clean if dirty. Remove the lens and gently clean the gold contacts on the back of the lens and in the lens opening of the body with a pencil eraser. Don't let the bits fall inside the body. Try the focus outdoors in good light of a scene with lots of clutter in the frame to see if the problem only occurs in low light. Check the menus and make sure the focus assist lamp is in the on position. Let me know if these solve your problems.
Posted on Sep 27, 2009
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Canon can't lock focus
you have to keep your finger half pressed down or it will always refocus and also do a new light reading.if you keep your finger half way down and reposition it should stay locked
Mar 29, 2012 | Canon PowerShot A590IS Digital Camera...
When filming or not the picture becomes blurred for a few seconds every few minutes. Please can you help.
It sounds like it's simply auto-focusing. When you're filming and the camera auto-focus sensor detects a new focus object, it will attempt to refocus on the new object. In lower light situations, this may take longer for the sensor to read the new object. The only way to resolve this is to turn auto-focus off (if your camera allows it). If your subject area remains in the same plane of focus, you shouldn't have any focus issues. If it changes, however, you will have to manually refocus to the new plane, just as you would with a manual camera.
Hope this helps!
Mar 02, 2011 | Cameras
While recording the Camcorder goes in and out of focus. If I keep the camcorder running and either zoom or pan out the subject refocuses, but if i hold at that level of focus the subject becomes blurry...
It sounds like you are either too close to the subject or you need to flip the focus switch to automatic.
The Auto/Manual focus button is located on the left side of the camcorder under the LCD monitor flap.
Other than that, does this happen only in low light? The camera will have trouble focusing in low light usually.
Mar 01, 2011 | Panasonic SDR-H40 HDD Camcorder
My Pentax Optio W10 camera takes some out of focus photos. What do I do to solve this problem?
Your camera has the option for manual focus. This option allows you to focus the camera to capture what you want, rather than the auto-focus feature.
This will be indicated by a MF in the top center of your camera screen. You should be able to change this by finding record mode and changing your AF settings. Change your MF to the [ ] option and you should be on auto-focus settings.
Hope this helps.
Chadlnrd
Feb 28, 2011 | Pentax Optio W10 Digital Camera
Constantly refocuses while taking video
If you aren't planning on zooming in or out, you can lock the AutoFocus by:
- first assign the shortcut key to the AFL (Auto Focus Lock) setting (by going to Menu, then "Set Shortcut button") - then while filming, press the shortcut key (which you have assigned to the AFL setting) and the focus will adjust and unlock (the AF will unlock when you press any other button). - each press of the shortcut key will adjust and lock the focus
Dec 20, 2009 | Canon PowerShot SX20 IS Digital Camera
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
Apr 10, 2009 | Fuji FinePix S7000 Digital Camera
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CAMCORDER IS BLURRY IN AUTO AND MANUAL MODES IN ALL ENVIROMENTS
The camera is less than a month old and this sounds like a s/ware issue within the camera.
take it back to the shop where you purchased it.
You should be able to do a straight swap.
hope this helps.
Feb 07, 2008 | JVC Everio GZ-MG130 Camcorder
Auto focus will not focus. lens problem or camera problem?
A dirty filter, front, or rear optic can cause the lens to seek
Feb 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Nikon D80 Digital Camera Logo
155 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
