Question about Panasonic DVD-LX8 Portable DVD Player
When a dvd is playing the screen is very dark and the images cannot be seen
  • 63 Answers
Try to chenge the brightness.
Posted on Sep 27, 2009
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
Image ghosting
does the entire screen have that symptom or is it mainly one side or section all the way across the screen. Does it also go away after the set runs awhile.
Aug 12, 2012 | Sony Televison & Video
Akai portable dvd player - broken screen
ur player lcd is damaged or loosened take it to roduct service center and they will do it ok
Mar 30, 2010 | Televison & Video
When playing DVD, image sometimes dark incl. closed caption
1> sometimes supply of low voltage causes some disturbance in trasmitting video signals,it results in darker images while watching.
2> The DVD may have some scratchs or dust-spots or rough-coat on its recording surface ( reflecting LASER beam ) clean DVD and operate again.
3> your DVD player's SMPS (switched mode power supply ) circuitary fails to perform its function properly and giving irregular supply to video-audio card of the DVD player because of having some failure of electronics component housed on this circuitory.
4> switch the mode among 'PAL' , 'NTSC' , 'AUTO' and OTHER in playback mode options ,one by one taking  some minutes.
Now , your problem is solved , Enjoy,Bi.
Nov 29, 2009 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Coby 224 Screen Slowly Fades to Dark and Back To Light
Usually if your getting it with the MENU then your connection is weak, are you going through a VCR or some other type of device besides directly to the tv? Try hooking unit directly to the tv. Besides that, its possible you could of messed with the settings, go to the menu, go to advanced and do a reset to make sure no settings were adjusted, the disk has to be out of the tray while you do the reset.
Jul 14, 2008 | Coby DVD-224 DVD Player
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Sep 04, 2007 | Shinco SDP-1750 Portable DVD Player
Panasonic DVD-LX8 Portable DVD Player Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
