Question about Delta 10"Hybrid Tablesaw with 30"Unifence
I have an old Delta 10" table saw. I don't know the model number but the S/N is 26-1414. I need to change the belts (3) and don't have a clue a to how to do it or where to get the belts. Can you help.
    Sergeant:
  • 232 Answers
Go to tool parts direct and search for your tool. there are exploded diagrams and parts lists.
Posted on Oct 16, 2009
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
Where can i get an owners manual for a Delta Table Saw?
you might try Dewaltservicenet.com and you would need your model number for this. If you can't find let me know and I will try another source
Aug 31, 2010 | Delta Machinery 10" Professional Radial...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
The motor on my delta 10" table saw starts a low rpm and does not go into high rpm - after a a few seconds it fails the circuit breaker, and without the belt conected this does not happen. Is the motor...
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Jan 30, 2010 | Delta 36-716B 10" 1-3/4 HP 120/240V...
10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Nov 27, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
I need an instruction manual for my delta shopmaster 10'' bench saw model number TS200LS. I know very little about table saws and need to change the blade and would like to install a dado blade.
you might try Dewaltservicenet.com and type in your model number in the middle of the page under need manual and see if you can find it there if not let me know and I will try and find one for you.
Nov 21, 2009 | Delta Saws
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
119 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
