Question about Garden
Where can I get a new wand for a delta 2450 power washer
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Hi have mac allister water leeking out off trigger
the seal in the plunger valve of your wand is bad or possibly it froze and cracked...either way to work on it far exceeds the cost of a new one so you will just save yourself time and money by buying a new wand at a local dealership...good luck
Oct 22, 2014 | Karcher K2.26 Electric Power Washer
Why is my detergent not working on my new k5 pressure washer
If you are referring to an electric washer,The wand for the detergent is a double action wand. You usually pull the wand end out for low pressure and detergent flow.
May 30, 2014 | Garden
A leak at the base of the pullout wand on a Delta faucet
Check the water connection to the wand to make sure it has a gasket in it .
Aug 16, 2011 | Delta Model 474: Waterfall Kitchen...
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
Low pressure from wand
where do i get a washer for the wand?
May 21, 2010 | Simpson PS2600 PowerShot Commercial-Duty...
Very low pressure on delta 470 faucet
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
Jan 16, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
