Question about Garden
How to re assemble recoil spring on macallister pro 50 lawn mower. I have inherited this machine which has only been used a few times and the previous owner has given up on it. The whole recoil housing has been taken apart and there are no instructions with it. I have tried to find a schematic for the said beastie but to no avail so far. Any ideas how I can coax the spring back into its casing with the flywheel in place and the pull cord in the right direction??? I have broken two nails so far on this and am getting cross.
  • 37 Answers
Hello there it is hard to do but with patients you can put a loop of tape or a cable tie around the start of the coil and everytime you rewing the coil you can put it under the loop to keep it in place hope this helps
Posted on Oct 08, 2009
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
What is wrong with a toro push mower when the pull cord hangs up will not pull out
Pull plug, see if worked. To munch fuel some times. Next pull recoil assembly the spring may messed up.
Mar 11, 2012 | Toro Power Lawn Mower
I need to replace the pulley and recoil spring assy on my victa statesman mower,how do i do it?
Most recoil assemblies are secured with three machine screws that once removed, allow the assy to be lifted off. The new assy simply reattaches in the same location.
Gary
Jan 06, 2011 | Garden
How do I replace a recoil assembly on lawn mower
Its typically only two or four screws to replace the entire assembly. But I would try to replace only the cord or spring first
Oct 03, 2010 | Husqvarna 21" Lawn Mower with Honda GCV160...
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Sep 20, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
178 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
