Question about Garden
Engine removal on walk behind blower
How do I seperate the fan from the engine on a super vac walk behind blower.Do i need some sort of tool like a steering wheel puller?
5 Suggested Answers
  • 398 Answers
SOURCE: sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Posted on Mar 20, 2009
  • 864 Answers
SOURCE: blackanddecker gw3000 blower vac how do you
See if this helps: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90517736,%20BV4000%20.pdf
Posted on Sep 21, 2009
SOURCE: Replace right front wheel-self propelled walk behind mower
Leaned on it
Posted on Feb 04, 2010
woobie dog
  • 1273 Answers
SOURCE: How to convert blower to vac. Toro 850 super
Remove the air inlet guard on the bottom by pressing the release and pulling down on the guard. It will tilt off. Remove the blower pipe from the front of the machine by pressing the tab and wiggling it off (It is usually a tighter fit than the air guard). Install the vacuum pipe on the air inlet, where the guard was removed. Install the bag where the air blower pipe was removed.
Best regards, --W/D--
Posted on Jun 04, 2011
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
While driving with heat on smelt chemical smell and plastic smell. Looked back behind seat to the vents in the center console and saw smoke coming out of vents.Is my blower motor out and how do I...
there is a seperate fan switch on the control panel located on the rear of the console. remove inner console and inspect wiring first. it also hosts a seperate blower than your dash blower so any sign of melted wires can be replaced.
Jan 02, 2011 | 1998 Ford Explorer
My 3 year old 22 inch walk behind mower will not start, I replaced the spark plug, there is no spark when I pull the hand start
Replace the flywheel key by removing the rewind housing, the flywheel nut and then remove the flywheel by using a small engine universal puller (cheap) and install a new key.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
ROOF Ramrod impellar removal
I just acquired an original manual for my Ramrod, which states:
"Four blade impeller made of 1/4" steel rotates at speeds up to 3600 RPM (In the 5 hp model). Impeller is keyed directly to the engine crankshaft by 1/4" key and held in position by a T-head cap screw."
The cap screws also vary between the 3 and 5 hp units, but the over-all setup appears to be the same.
Nov 27, 2009 | Heavy Machinery
Motor still runs--sounds like jet engine. do I need a new motor? or is there some sort of muffler that has malfunctioned? vacuum belongs to disabled mom---so trying to do work ourselves--cant afford much....
This little vac I think is actually made by Samsung. If it is ROARING and vibrating, either the bearings or suction fan is in bad shape. Remove the lid as if to inspect the belt and see if there is a visible intake opening with a plastic fan rotating inside. If so you have to inspect for damaged fan blade . A broken blade will cause the noise you describe and can be fixed on most vacs by carefully opening the fan housing and unscrewing,the fan from its threaded shaft. Then screwing on a new matching fan. Post back with more info and I`ll try to walk you thru the process
Sep 13, 2009 | Bissell 3590 CleanView Bagless Upright...
Bought used Giant-vac walk behind leaf blower.
The model number that you posted looks like a briggs model. You can go to any briggs dealer and buy the engine manual for this engine. That will give you the procedue for rebuilding the carburetor which looks like a place to start. I also think that giant-vac was bought by some other company thus you may have to do some research on the internet.
The parts manual for the engine is on the briggs internet site.
good luck
Mar 29, 2009 | Garden
Leaf Blowers types
* Handheld units are the most popular. Available in gas- or electric-powered versions, they're portable and convenient, yet powerful. These models can get heavy while using. Larger models can also vibrate a bit at full throttle. Consider the weight and balance of the unit when shopping. * Backpack leaf blowers are gas-powered. The blower fits in a harness that's worn on the operator's back. The hose reaches to the front where the user operates the throttle and blow or vacuum tube. Backpack blowers are normally used in larger areas. * Walk Behind leaf blowers cover the most acreage. Mounted on wheels, these gas-powered machines are normally the tool of choice for commercial users, but for regular homeowners, they can make short work of a home lawn. Vacuum units use a hose for picking up debris.
Aug 27, 2008 | Toro Super Blower Vac
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
