Question about Samsung SGH-t229 Cellular Phone
I try to connect the bluetooth and it gives me a no bluetooth device found?
2 Suggested Answers
techguyuk
  • 33 Answers
SOURCE: bluetooth
Hi, usually you choose the pin yourself, so just type 12345, then it will ask you for the same pin on the other device, type 12345 again, and this should pair it to your PC. Hope this sorts it out for you, if not, post a little more detail and I will do the best I can to advise. All the best. Si :)
Posted on Sep 26, 2007
Hi i want to connect Nokia BH 503 bluetooth to dell inpiron laptop, it is detecting the device but could not connect it.
hi my headsent nokia bh- 503 is not connected in mylaptop my laptop want the bluetooth driver peripheral so this driver not found so you give me any web site then i install the drive give my answer
Jul 02, 2012 | Nokia BH-503 Bluetooth Headset
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
How to connect bluetooth device on LIFEBOOK AH530
You are going to have to pair your device with your computer. Open the PC Bluetooth manager. Select seek all devices when connected. Make sure to check that option. Turn on your device making sure that it is also set to seek a connection once PC has found the device. The software will open a window that will give you paring code make sure that you type the code into the box it has to be perfectly done. Then the devices can be paired up. To see if you located your Bluetooth device go to devices you should see your device there. If not click on add new device make sure your device is turned on again able to seek. It will connect to the PC.
John
Apr 20, 2012 | Fujitsu LIFEBOOK AH530 NOTEBOOK (FPCR33681
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Hello, I just purchased an acer tablet, and I'm trying to connect and use my wifi from my mytouch android cell phone, but its not connecting. What am I doing wrong?
you cannot connect two mobile devices because that two devices are only receivers so you need a transmitters such as the laptop or a wifi router and then using that you can connect your two devices
Jun 12, 2011 | Acer Computers & Internet
What is the passcode of the bluetooth?connecting to a computer
The passcode for connectivity will probably be listed on your computer once it finds and attempts to pair with your phone. Generally when connecting a Bluetooth device, a passcode will be displayed on the host computer in order to ensure that only authorized devices are being connected.
Here is a guide I found for setting up Bluetooth on this device:
http://www.knowyourmobile.com/sonyericssonk800iuserguides/255/setting_up_bluetooth_on_the_sony_ericsson_k800i.html
Mar 02, 2011 | Sony Ericsson K800i Cellular Phone
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Samsung SGH-t229 Cellular Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
