Question about Refrigerators
Ge profile Fridge. Evaporator fan icing up
The evaporator fan on my fridge keeps icing up and stops functioning. I have noticed it twice and been able to open up the evaporator section and manualy defrost with a turkey baster and some hot water which seems to work for about a month.
  • 2 more comments
  • Anonymous Jan 13, 2008
    I have the same problem. I've been told by 2 service techs that it's a design flaw. And they recommended spreading out the round coils as much as possible. This can be done by removing the little square foam 4 in all, located at each end of the coils and then pulling gently every few coils, Wait until they are defrosted to do this or you might find your hand stuck. Still waiting on outcome to see if this will be a permanent fix, Why they didn't just add a heater to the tube is beyond me !
  • jason stumbaugh Feb 03, 2009
    i have the same problem i use hot water and a towel. i wish there was a permanent fix i do this once every other month!
  • wavell Apr 09, 2009
    Same problem here with GE design flaw. How do you remove the evaporator front and top panels to gain access to evaporator unit between the top fridge and bottom freezer?
  • Anonymous May 07, 2009
    Just happened to our fridge too......
fridgetech
  • 473 Answers
SOURCE: Kenmore Fridge 596.76509500
KentC, This was my post on a model like yours.  Read thru this and let me know what you find.   If the ice/frost buildup is fairly thick and only on the back freezer panel then you have a defrost problem. Most likely the defrost thermostat is bad. It would be hard to explain how to test this in writing but there is a tech sheet underneath the fridge behind the grill on the r/f. It is in plastic which is stuck to the fridge. This tech sheet will tell you how to put it into diagnostic mode. First take the back panel of the freezer off (may need to get frost off first). Should be four 1/4" screws in each corner of the panel to remove. Will need to remove racks, door (should just lift off), and ice maker first. Remove vent in center of freezer panel by pushing up little tab in the center of the vent and using a screw driver to pop it loose on each side of the vent. Then remove thermistor cover on right hand side of panel. Remove (by pushing thru) ice maker plug. Once the panel is off put the fridge into defrost by the instructions on the tech sheet. If it goes into defrost (heater will get hot) then the main control board is bad. If not shut the doors to reset, defrost evaporator with a hair dryer and remove the defrost thermostat. It is a little metal round piece with two wires coming out of it and just clips onto the evaporator. Cut the two wires coming out of the thermostat, strip them back and splice them together. Now put it into defrost again. If the heater comes on then you know the thermostat is bad. Diagnostics mode can also test all functions i.e. condensor motor, compressor, evaporator fan, and thermistors. With all of that said, if it isn't a thick frost buildup the evaporator fan motor may be bad which is the most common repair on this model. It sits just behind the vent in the center of the freezer panel. Let me know what you find.
Posted on Oct 20, 2007
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
SOURCE: evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Posted on Apr 29, 2009
SOURCE: evaporator problem on refrigerator
if you have a gas leak then you find the liquid boil off very early in the evaporator only, there should be no visible frosting until after the end of the capillary
Posted on May 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frost free failure on a GE fridge. Removed access panel to freezer section to find evaporator coils crusted in frost. Cannot locate defrost timer and cannot locate any repair manuals online. I'm not w
The defrost timer is electronic and built in to the main control board on the rear of the box.
The defrost heater and defrost thermostat are the most likely culprits on this brand.
They are in the freezer above and below the coil.
They usually come as a set.
Posted on May 24, 2009
I have a GE profile pfcs1njwass fridge making a whistling noise. I read somewhere that the part responsible for this was recalled and ge will replace it free. Does anyone know anything about this.
Sounds like either the expansion orifice or the evaporator fan. Take a mechanic's stethoscope and place the probe on the evaporator tube(s). It will be louder on that if it's the orifice. Sometimes they will make a sound if the system has too much refrigerant charge. Either case unless you are a fridge tech suggest have a tech do this one for you.
Occasionally the evaporators get an ice build-up which can cause strange sounds.
Maybe as a last ditch test before you replace the fridge, try defrosting it overnight.
Jan 16, 2018 | GE Refrigerators
WHY THE FREEZER FUNCTIONS BUT THE REFRIGERATOR SECTION DOES NOT FUNCTION ON A GE PROFILE BRITA FRIDGE?
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
My GE profile performance refrigerator is not as cold as it was
is the evaporator fan working, which normally make the food compartment cool.Are the cooling passages clear, if the fan is not functioning, it will create and ice build up which then needs to be defrosted by shutting it down or with a hair dryer or heat gun.
Jun 08, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
Temp is rising and fridge is making noise
the problem lies with your evaporator fan motor, ice is forming underneath the fan blade, and as one customer told me, it sounds like a helicopter. when this fan stops altogether, no air flow to fresh food section is a result.
the cause could be the fan motor itself is bad, or if there is ice underneath the fan blade, the defrost drain is clogged with ice. after clearing the drain, i would highly suggest putting a defrost drain heater, to prevent ice build up in drain,, from obstructing fan blade. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
Refrigerators Logo
891 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
