Question about Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD-50PX2 won't turn on
I have a Sony FWD-50PX2 that isn't working and I am trying to fix. When its plugged in the green LED on the front lights up. Then a click is heard on the G board, two green LEDs light up on the CTRL board, first D15 then D18 (D16 and D17 never come on). A "whirring" sound is heard on the Y SUS board and a rapid chirping sound from the X/Z SUS board. Then the D1 green LED lights up on the CTRL board. This is followed by the D2 green LED briefly flashing on the CTRL board followed by another click on the G board. The process then repeats itself another 4 or 5 times before it stops completely and the LED on the front of the tv turns and stays red. Please help. Trying to avoid taking it into the shop for lack of funds. Thanks.
  • 3 Answers
SOURCE: Sony FWD-42PV1 -
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
Posted on Apr 24, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 115 Answers
SOURCE: no display r sound
I can tell you exactly which 3 dollar part to replace . But i put my time into my education and if i just tell you for free my kids will go hungry.
Posted on Oct 05, 2009
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
  • 608 Answers
SOURCE: How to fix a fan
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Posted on Dec 10, 2010
Flicker screen
If any buffer board is faulty, this kind of fault can occur. Might have a panel fault too. It will be best to contact any service technician, to make it confirm. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 16, 2013 | Sony FWD-50PX2 50 in. Plasma Television
Picture flickers and clicking sound coming from back of t.v.
The Z-Sustain should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Faults to almost all brand Plasmas will be the same as they are all built on similar chassis. Refer any one. You can get details.
Nov 14, 2012 | Sony FWD-50PX2 50 in. Plasma Television
We own a Sony FWD-50PX2 television. A few weeks ago it would not turn on. The power is going to the television. When you try to turn the tv on you can hear it pop and the red light showing it is off...
this is a common issue i think. below steps solved this issue for an user.
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 23, 2017 | Sony FWD50PX2/S 50 in. Plasma Television
My Sony Flat Panel Display FWD-50PX2A : When I plug in my Sony the green light goes on a ticking noise appear and after a couple of seconds the red light goes on - neither the remote or manual buttons...
Unplug,replug tv back in an hour later.Tv now reset it self back to factory setting.Now it should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 13, 2010 | Sony FWD-50PX2 50 in. Plasma Television
I have a Sony fwd 42pv1 tv and every time I turn it on there is no picture. Like you can hear it click when it turns on and the LED is green but no picture. And when I turn it off it clicks and the LED is...
This is more then likely the power board. I have a complete board set that I will sell you for $150. The screen I had was bad so I just removed all the working boards. They are all like new. If interested email me at theetrader@hotmail.com
Aug 14, 2010 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Sony Plasma TV.
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Sony FWD-42PV1 -
Jan 26, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Jun 24, 2007 | Sony FWD-50PX2 50 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
