Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Picture and sound are not working.
Green light on front flashes when turned on and a clicking sound comes from the left side on the bottom. Also, the lamp light came on but now does not come on.
    Genius:
  • 1,112 Answers
Replace your lamp, This will resolve your problem.
The clicking sound is the Ballast trying to start the lamp.
Posted on Nov 03, 2009
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
Driver side signals only work when headlights are OFF
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
Apr 22, 2009 | 2004 Dodge Intrepid
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
Philips 42fw3090/17 don't turn on, only LED comes on red
first thing i would do is take the lamp out and look at it, it dhould be on the left side of the tv, you will see a little door at the bottom
Jan 10, 2009 | Philips Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
