Question about Amana Refrigerators
I have a 25.9 cf Amana side /side. The hose going to the ice maker pulled away from the housing. Can this be pushed in and reclamped?
  • pjjwhalen Sep 26, 2009
    Tom you were right about it being frozen. Took the tube out and unfroze but the housing that feeds the water to the ice machine, has a piece inside. Does the housing, up top right, come out or is there a better way to get that ice out. Thanks much
    Right on the money. Saved me a service call and alot more that the price paid for this information. GREAT. Thanks Tom
  • 220 Answers
You said it pulled away from the housing,the housing of what?the tube runs from the water valve on the bottom of the fridge to the inlet tube on the top right,if it came loose from the top/inlet tube you can just push it back in and clamp it,But,there is no pressure on that end of the line so the inlet tube going through the wall to the ice maker may be iced up meaning it is clogged with ice creating back pressure and causing the line to leak or pop off,so I would check the fill tube,you can see it from inside the freezer,it comes through the back wall of the freezer and goes into the ice maker,depending on the age of the unit most of the inlet tubes can be pulled out from the back by turning it a quarter turn to the right and sliding it upward and out.
Posted on Sep 26, 2009
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
Water in door but no ice?
there is no pump, just water psi from your house.
check inlet valve to ice maker/water float
Sep 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Helping parents out. They have an Amana two door
First you need to get hold of a replacement hose - preferably original parts.
After this - the door will come apart at seams possibly by removing the ice dispenser assembly first. A lot of things are designed to clip in, but secrews are often used as a back-up.
Aug 28, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The tubing for my Amana SRD25S5L is brittle and breaking. Where can I find replacement tubing or repair kit?
If you're refering to the ice maker supply tubing, you can get ice maker hookup kits with the proper tubing and ferules at a local hardware or plumbing supply house.
Save your fittings as you pull them off to reuse what you can, you may need to replace the compression ferules on the plastic line under the compression nuts.
Be sure to pressure check for leaks before moving the refer back into position.
Jul 13, 2009 | Amana SXD524VW Side by Side Refrigerator
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker
replace micro switch above the ice maker lever in the dispensor housing
Jan 22, 2009 | Amana ARS2464B Side by Side Refrigerator
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
