Question about Garden
My lawn tractor will not start. Turns over and then backfires. Any ideas what I should do?
  • 986 Answers
The timing is off, check your flywheel key and replace it if it is partially sheered this will throw off your spark to be little or non at all. Assuming it has electronic ignition the only three parts you need to produce correct time are cam to crank timing mark match up [for proper ignition timing ] and a solid flywheel key to line up the flywheel and crank for proper spark build up between coil and magnets on flywheel .
Oil out your exhaust could be from too much oil,a plugged vent tube from crank case vent to carburetor will cause crank case pressure to push oil out of the engine through seals,exhaust valve guides up into combustion chambers too ,If the pressure gets too great it can blow a motor up .
I am susspecting the valve timing is off ,The oil coming out the exhaust at the far side of what I believe to be going on without seing it in person, could be a bad ring but doubtful if it was maintained reasonably well .
Posted on Sep 26, 2009
Tractor will not start.
Are you getting spark to the plug(s). Check with spark tester. Is fuel getting into the cylinder(s)? When it turns over, do you get a spit or backfire? If yes, check flywheel for key.
Dec 05, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
My lt1000 turns over and while turning over backfires. does not start. Started backfiring a couple weeks ago while in operation. would backfire, engine would die, wait a few and started again. finally,...
The engine should be an OHV type. You could try adjusting the valves under the OHV cover. Kinda like the valve lash on cars. When the valves are at rest you can set each one to about .004 with a feeler guage. You can look on youtube for a video one adjusting lawnmower engine valves. Seeing it is easier to understand then reading it.
I hope that this helps you get it fixed.
Jul 17, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Backfire won't start now turns over
coil or coil packs are bad, also check for fuel to make sure it is getting gas.
Jun 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
