Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna transaxle not as responsive as should be
    Problem Solver:
  • 5 Answers
Lube the valve linkage.
Posted on Oct 01, 2009
Will the transaxle from a Husqvarna GTH 2448T Hydro Gearr part # 316-0610 bolt into a Husqvarna LGT 2654 that currently has a broken axle in a Tuff Torq transaxle
Yes, the axle will fit the frame, but the pulleys and idlers will need to be set up. There is no cross reference chart so you would have to create the belt routing by trial and error. Belt length would also have to be determined.
Aug 07, 2016 | Husqvarna Garden
How to replace the brakes of husqvarna lawn mower?
unfortunately, you are one of the lucky owners that has one of these things. You are going to have to remove the transaxle and break it down in order to replace the brake pad, "IF" you can find a replacement part! My suggestion is to double check the linkage and use you owners manual to see how you can or if you can adjust the linkage. Replacing the pad is not all that difficult but it is very time consuming. If you have to remove the transaxle to replace the pad, please be sure you have a breakdown list so you can disassemble and reassemble the transaxle correctly. You will need to find the exact model number on the transaxle and then look it up online and download a copy and print the breakdown section. Good luck.
Aug 14, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a husqvarna LGT2554 54" mower will not move do this mean transaxle need to be replaced or a part put on?
If the transmission is a hydrostatic (automatic) and this has been slowly happening, yes the transaxle could be bad and need replacing. If this was sudden, check your belt. If you have recently changed a flat tire, make sure you put the drive key back on the axle.
Jun 24, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Husqvarna YTH 180 transaxle fluid
If it is not leaking there should be no need to add oil, if it does not have an external resivoir you would fill throught the filler and leave a 1/4" air gap to allow for expansion.
Aug 10, 2012 | Husqvarna Garden
Tractor moves fine when cool but after using for a while transaxle barely moves I have a Husqvarna YTH 150
This is the sign of worn internal components, as the unit heats up so the oil gets thinner and leaks internaly, this is a rebuild or new transaxle, you could try changing the oil but this does not always help, and if it does it is usualy short term.
Jul 11, 2012 | Husqvarna Garden
I have a Husqvarna YTH 150 lawn tractor and the left axle from my transaxle twisted off.
Typically the axle is part of the transmission. Unless you have knowledge or experience in disassembling them you might want to just find another transmission and install it.
Dec 12, 2011 | Husqvarna Garden
Transmission fluid low, hydrostatic transmission will not run in high position, where do i fill fluid
Quoted from your Owners Manual. . . . .
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance is not required for the life of the transaxle. Should the transaxle ever leak or require servicing, contact your nearest authorized service center/department.
Oct 29, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
95 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
