After paper jaming, its better if u could remove the papers without openint the back key. If you opened the back key and return it after removing the papers, there is a big chance to have this (power on) problem. Thanks moiyasser, I tried your method, and succeded but with several attempts.
I'ts because there are a paper jam
I have the same problem and I solved it myself
-.... look into the lock behind the printer remove it then put it back again >>>>>>>>
moiyasser,
thank you so much, this little problem was beginning to give me a headache.
the same problems jabba3
16
This is a 3 month old printer. It's been back to the repair shop twice when it would not switch on. They couldn't fix it so they gave me another one. This one does not print. The documents line up in the print queue but nothing happens. I've spent hours trying to get it going. Have uninstalled and reinstalled and downloaded new drivers and tried all the USB ports. The colour ink tank is low. Will it fail to print even in black if this is low? Should I try kicking it? Help would be appreciated but I feel this model is a lemon.
Am having a power problem, every time I on the power it goes up after 2 seconds and if I ask it to print a document it indicates 2 lights green and yellow at the same time.
Please help me to solve this problem.
My printer is going to on just for a second how will i fix it?????
