Dell monitor model e152fpc error code "can not display this video mode"
  • 5,568 Answers
Either the monitor or your video card may have been wounded or Windows has simply trashed the driver - it likes to do that, otherwise it would just get too boring, right?
You should try another monitor to see if Win likes it better. If you get a usable display, your monitor is likely at fault and not responding to the sync signals supplied by the video section. If you get the same error code on another monitor, then your video section is ailing and if it is an on board chipset, you may have to replace that failed section with a discrete card and disable the on board section through the BIOS setup. Good luck-
Posted on Sep 26, 2009
How do I get rid of flashing Display mode out of range message
Terry,
That monitor only has VGA in port. So it sounds like the computer VGA out port is not sending a correct 1024 x 768 at 75 Hz signal to the monitor. The problem could be a defective video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2015 | Dell E152FPc 15" TFT LCD Flat Panel...
When I turn off my Dell monitor E152FPc for hours, the monitor blinks and will not come on until I have turned the monitor off and on a lot of times
The power supply board is on the verge of failing, the cause is often a bad capacitor that opens, in some cases there may be more than one involved, leaving a bulge at the top leaking it's contents making it easier to nail down.
Jun 03, 2012 | Dell E152FPC 15INCH FLAT PANEL LCD MONITOR...
Manual monitor e152fpc
there are two resistors with copper platr attached replace them. it will mean soldering. remember. 4-12-02 on the power board well she's old.
Dec 09, 2011 | Dell E152FPc 15" TFT LCD Flat Panel...
When i on the monitor it shows that it is on but in some second it doesn't show anything its like is reducing the light show the display in low opacity you can not observe clearly so what is the...
Right now the backlights circuits go into shutdown, this can be due to bad power supply because of the bad caps, bad fuse in the inverter circuits, bod solder joints, bad lamp assembly, etc. It will require in-depth troubleshooting.
See example of failed Dell's here:
http://s807.photobucket.com/albums/yy352/budm/DELL/
Please read my guide for more details:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 11, 2011 | Dell E152FPc 15" TFT LCD Flat Panel...
My E152FPc on lite does not come on & no picture, How can I repair?
Did you check the driver is installed if there is one and all the cable is connected well? Tried another E152FPc on lite?
Dec 05, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
How do i open a Dell TFT monitor model 1505?
poginga, Try visit to YOUTUBE for video clips "lcd monitor disassembly" and or "lcd monitor repair" to get basic idea of how to !!! DO NOT USE SHARP BLADED INSTRUMENTS OR YOU WILL END UP IN THE LOCAL "ER" TRYING TO EXPLAIN THE BLOOD GUSHING OUT FROM YOUR BODY" 12fixlouie
Feb 22, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
No video. Power is good but no video signal from cpu
Try this:
While powered and connected to the computer, shine a very high powered flashlight on the screen. You should see a faint shadow of the display from the computer. If so, your inverter board or backlights are blown. If not, the LCD controller matrix may be blown. Either way, I would suggest just getting a new monitor.
Nov 20, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
LCD monitor no display - flashing power button
hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
Apr 21, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
My monitor do not work right
Are you saying that you can faintly see your desktop or just the reflection of your desktop??
if you are saying you can faintly see your desktop it means that the fluorescent light isn't firing up properly, take it to a repairman or if its under warranty, take it back for a swap or a refund.
Mar 24, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Vista video driver needed for Dell E193FP
There are no drivers for difrent monitors.
But if you provide your pcs brand, name, model.
I might be able to find a videocard driver witch might fix your problem.
Oh and what videomode are you trying to use?
Mar 11, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
