Question about Bryant 463AAC005BA Air Conditioner
Compressor and fan working no air from vents - Bryant 463AAC005BA Air Conditioner
  • 334 Answers
If the fans are working and there is no airflow, then either the filter or the coil is clogged. A remote possibility exists that the fan blades are extremely dirty or damaged.
Make sure the coil is not frozen over.
If your coil is frozen over, this tip will explain why.
http://www.fixya.com/support/r1430318-unit_freezing_up
Posted on Sep 27, 2009
Zfk56/52 not cold fan running compressor is hot to touch
Compressor getting hot is normal. Fan working is good. Make sure the inside fan works and that the vents are not blocked. Vacuum under the refrigerator so the air can circulate to the condenser coil. Good luck!
Dec 22, 2016 | Refrigerators
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
Compressor runs for a short period of time then kicks off, compressor fan is good. interior condensing coil fan runs well. temp is between 43.3F - 45.0F. Fins are clean on compressor. dial is set at 9,...
1 is freezer side ok?if it ok. it is easy. air vents blocked in either compartment.remove any objects from in front of the air vents.
2 evapor fan work ok.
3 how much frosts build up the evapor coil, if it build up to blockthe air vent. mayon the back wall of the rfrigerator self-defrost timer or deforst thermostat is bad
if it still not work. i have to see hat i an do for u. my e-mail is wongjimmysoon@qq.com
Jan 11, 2011 | True T23 Refrigerator
Central air conditioning unit blows air but not cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 29, 2010 | Amana Heating & Cooling
My airconditioner unit will not cool, compressor is running, but cold air will not come out of vents
mcdevito75 here, The compressor may be running but without the fan, no air will come out of the vents, Double check the fan operation on your A/C unit, turn the fan speed switch see if the fan is working if not, see your local A/C repair shop.
Jun 24, 2010 | Heating & Cooling
Air duct no heat coming out (forced hot air) vents open
what does this have to do with Air compressors?[catagory u selected] have no idea what we are working on here, please provide all details, make model and so on.
Jan 04, 2010 | Air Tools & Compressors
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
The compressor and fan don't come on when the air conditioner is turned on and hot air comes through the vents. However, when the relays are removed and a test wire is inserted into the relay port, th
Sounds like a bad heater control unit, or bad control module. You are bypassing the switch when you jump the relays, so usaully the switching mechanism is suspect.
Jun 02, 2009 | 2007 Ford Fusion I4 SEL Sedan
Bryant 463AAC005BA Air Conditioner Logo
105 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
