Question about Sharp 25R-S100 25" TV
Sharp 25" tv unknown model (no av in)
Single horiz line on sharp 25" tv, reverts to normal when case is tapped
Its dry sold problem. Resolding the pins of vertical IC will solve the problem.
Posted on Sep 09, 2012
  • 281 Answers
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Posted on Jan 24, 2008
Hello! I have a Sharp Liquid Crystal TV (37" display) and my menu options, specially the picture menu, is fixed. can you help me "unlock" it? Model # LC-37G4U
If the AVC System is switched on but it does not appear to be operating correctly, it may need resetting. In this case, press RESET, shown in the diagram, lightly with the end of a ballpoint pen or other pointed object. This will reset the System as shown below. • AV MODE resets to STANDARD • TV channel returns to initial channel setting (Air:2ch, Cable:1 or 2ch) • Twin picture resets to normal • Audio setting initializes • Dolby virtual resets to Off • Image position initializes
http://electro-medical.blogspot.com/
Nov 07, 2015 | Sharp Televison & Video
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Picture uncentered and no on creen display
U have to trouble shoot for leaky capacitors in the video and horizontal circuits/Areas
Jan 07, 2009 | Sharp 25R-S100 25" TV
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
Sharp tv on pure red
first check all RGB drive if have a normal voltage and sync signal if normal maybe the picture tube have damage ,try to replace the new one. gud luck
Nov 06, 2008 | Sharp 25L-S100 25" TV
Sharp 25R-S100 25RS100 SHARP 25" STEREO FRONT/REAR AV
Good day.
Try to check the crt socket. Also, check for the loose contacts along the Chroma IC. Like wise, there is a screen adjustment on the rear portion of the flyback. Try to adjust the screen.
Response is highly appreciated.
chris
Feb 24, 2008 | Sharp 25R-S100 25" TV
Troubleshooting tips
Solder any / all bad connects, check capacitors,esp.horiz drive.
Nov 07, 2007 | Sharp 25N-M100 25" TV
Trouble in sharp t.v.
Check horiz output transistor and solder any / all bad connects,
Check fuses.......T.
Nov 06, 2007 | Sharp 25N-M100 25" TV
Horiz. sharp line from 2 inch bottom
If the screen is part of your laptop/notebook/netbook, try to connect an external monitor to the VGA port, to see if the video-card in your computer is generating the "weirdness".
If the screen is an external monitor, try connecting it to a different computer, to see if the "weirdness" follows to the new computer,
implying that the monitor is faulty. Also, connect a diffferent monitor to your computer, to see if the video-card is causing the problem.
Sep 22, 2007 | Computers & Internet
Sharp 25R-S100 25" TV Logo
141 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
