Question about Black & Decker Garden
Black & Decker Grass Hog. The AFS string using 5 feet every 1ft.(uses 065 line)
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
  • 133 Answers
SOURCE: STRING IS USED WITHIN MINUTES. IS THERE A TRICK
Probably wound backwards. Follow the arrow on the spool for both. Both SAME rotation.
Posted on Apr 21, 2010
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
SOURCE: string will not advance on black and decker grass
Is it best to buy a spool for Grass Hog, than trying to re-string myself? String seems to get stuck.
Posted on May 23, 2010
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
How long does the trimmer last on a charge?
how long is a peice of string!!!!! how oftern do you use it as the charge will always die what ever
Jul 16, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
The auto feed on the grasshogs don't work
Replace the line with a star-shaped .065" line (I use Rino-Tuff from Home Depot online). I have the GH700 (2 line) model and it fixed the problem for me. Other people have fixed the problem with different shaped lines - apparently there is one at Walmart that works well on electric trimmers. Just don't use the smooth round line. I tried the manual advice and it was bunk.
Jul 13, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
23 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
