Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman Mower and blades won't engage
I have a Craftsman Mower and when i try to engage the blades they don't turn. I have checked the belt and they are all on track and the pulley that is being driven by the motor is spinning. The belt just wont catch and turn. I have tried using WD-40 on all the pulleys just to make sure they all want to turn. The pulley that tensions the belt also moves into place so at this point i'm at a loss and the lawn continues to flourish wildly.
  • kseger Sep 28, 2009
    The belt does tighten because the idler moves into place and no grass and blades aren't seized and moves freely. I think it may be that the idler doesn't tension the belt enough maybe??
    when i slide it to engage it does stick a little bit and the stick feels to be more stiff than before..if that makes any difference?
  • Chuck
    Chuck May 11, 2010
    Does the belt tighten up when you engage the blade lever? Have you looked under the deck for excessive grass build up. Have you checked each blade to make sure that it will turn freely?
  • 389 Answers
Yes, that would make a difference. I have seen the pivot point get rusted and dirty to the point that they wouldn't tension the belt enough. Locate the bolt where it pivots and loosen it just a little, then see if the belt gets tight. It must be really tight when engaged almost like a fan belt on your car in order for it to work. I would also recommend that you take a close look at your belt. It could be burned and have a flat spot since it has apparently been slipping. A flat spot on the belt will cause major vibration when the blades are turning.
Posted on Sep 28, 2009
Testimonial: "Helped alot thank you"
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Tractor shuts off when clutch is engaged craftman 22 hp 50" mower
I had the same problem. My problem was something was preventing the blades from spinning, so the 1st thing you can do is check to make sure your blades turn, and test this while the mower is off.
While it is a pain, you can also take the deck out and check to see if this help and you are able to freely turn the blades. If everything is working properly, you should be able to turn the blades by hand.
In my case, I has a stick jammed into the belts and pulley, so when I would engage the blade, it would cause my mower to stall when it tried to engage the belt.
Hope this helps.
Dave
May 29, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Blades will not engage, belt not broke but is very old, do I need new one?
Check if the belt is loose. With the engine off, try to pull the mower deck belt around by hand. If you can pull it easily, and the blades don't turn, then replace the belt. If it's hard to pull, and you can see the blades try to turn as you pull it, then your problem probably isn't the belt, but the PTO clutch or mower engage switch.
Jun 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Mower runs but blades won't engage.
first check for a blown fuse (owners manual will tell location) next try checking the blade engage switch next check the electric clutch good luck
Sep 10, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
504 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
