Question about HP Pavilion dv6227cl Notebook
HP DV6227cl will not boot up
I have an hp dv6227cl laptop that will not start up.i have unpluged the battery inside for ten min"s. and have have removed the battery witch i know is bad and willnot charge. I have tryed a new hard drive as well i have tryed a diferent power supply with the same results. all I get when I power up is all lights on pc come on as they normaly do. I hear the fan,cd drive and harddrive spin a few times and thats it. it will sit there about 15 seconds and lights will go out and come back on as if was restarting only to get to the same point and sit there or shut down completly.
  • Kelly
    Kelly Sep 27, 2009
    no there is no video sorry!! I am told now that it had shut down a few times in the last week and seemed as if it was over heated. But will not boot up from a cold state.
    President:
  • 1,015 Answers
Have you tried removing the hardware components and then starting the computer? Remove the cd-rom,hard drive and memory dimms and the boot up the computer. If it does the same thing then the motherboard or on board video may have died. Now you say you have removed the battery that is bad and will not charge. Did you install a new laptop battery? Did you test the watch battery in the motherboard for the bios and see if it is good? Use a fluke meter to test the output voltage of the motherboard watch battery and see if it is dead or has the proper voltage. A battery like that only cost a few dollars and may fix the problem...or it might not. But it sounds like the bios got erased or damaged and most bios chips are not removable. The ones that are require a device to re-burn the bios software onto the chip.
Posted on Sep 27, 2009
    Problem Solver:
  • 14 Answers
You didn't mention if you get any VIDEOs, I assume you DO... If not, check if you can get VIDEO OUT to a regular computer monitor... Now lets talk about your computer not being able to boot up where as it either shuts down or do nothing...
What I would recommend you do is REPLACE the THERMAL PASTE between the HEATSINK and CPU... Most of the time, if the paste is hard, it will not obsorb the heat well and causes the laptop to over heat and shut down or crash and do nothing.
Posted on Sep 26, 2009
Lock A and Lock 1 FLAHES AND SCREEN BLACK , HP Laptop 6530b
From what I can tell that means that something is happening during the boot up. I recommend that you press and hold the power button for a good min even after the power is off unplug and disconnect the battery. Put it all back together and see if that helps. If not you will have to flash the bios back if possible and see if it will get past the post and into booting the operating system.
May 04, 2011 | HP Business Notebook 6530b
My laptop is hp 6510b but problem is i forgott the bios password pls anybody help me
is a internal battery who store password and some boot config. needs some hand work. needs a tecnician.
Remove/disconnect the RTC-battery which is used for buffering the BIOS.
- Unplug AC, take out the main battery;
- take out the RTC-battery for app. half an hour (the period of 5 min as specified in the docs normally is not long enough);
- reconnect RTC-battery;
- plug in the AC adapter (battery still removed).
is the file who can help you.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01570696/c01570696.pdf
Jul 12, 2010 | HP Compaq 6510b NoteBook Intel Core 2 Duo...
My hp pavillion dv6000 does not boot again. The power light comes on and goes off after 2 minutes over and over again. How do i fix this?
Hi..
Unplug your sets of power cables and reconfigure complete setting from you laptop and wait for 2 min and just do the reset for two min and configure again..
Apr 08, 2010 | HP Pavilion dv6000z Notebook
Have an HP Pavilion Entertainment laptop computer that won't start. Keeps trying, but black screen. I've tried unplugging all devices (printer, mouse) and removing battery and plugging directly into wall....
Try holding down the esc button during a cold boot, as soon as you hit the power button you must hold down the esc key. Try it a few times waiting at least ten seconds between boots. If a screen comes up choose hard drive and computer should boot. This is only a workaround to a manufactures defect on the motherboard and will not fix the computer. But if it does post when you do this you will know it is a defective motherboard.
Apr 06, 2010 | HP Pavilion dv6000z Notebook
When powering up the system shuts on and off. It never gets the chance to boot up due to turning off and on.
unplug the battery, wait ten min, if that doesn't work the just leave laptop charging over night then try again.
Nov 02, 2009 | HP Compaq nc6000 Notebook
Charging problem
it can only mean 2 things:
1. your battery is charged
2. your battery is broken or not connected
Jun 10, 2009 | HP Pavilion dv6227cl Notebook
Laptop not turning on
Unplug it, remove the battery, count to ten, put the battery back in, plug it back in, and try booting again.
Is there a pin-hole on the bottom of your PC that says "reset" by it?
Has your PC been dropped or anything that may have caused physical damage?
Feb 26, 2009 | Compaq Computers & Internet
My cursor darts to a corner without moving mouse
do you have Word with that weird little paperclip helper? some computers have presets that make it (or your cursor) move out of the way so you can see what you're typing as that many people (not including me!) touch type while looking at the screen and the cursor being in the way is VERY distracting to them.
Jan 15, 2009 | Computers & Internet
My Laptop wont power on
Hi
Since your computer is not starting up at all its probably not a problem in the hard drive (where the files are stored) It is most likely a problem in the motherboard. Try removing the battery and ac then plug in the ac and try starting up, is the ac working? do you have a power light on the laptop that turns on when you plug in the ac adapter?\
If you don\t have a power light you need to get the ac adapter tested if the adapter is fine then most likely the issue is in the motherboard.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Ekse
Aug 02, 2008 | HP Pavilion dv6227cl Notebook
HP Pavilion dv6227cl Notebook Logo
322 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
