Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have a problem
My weed eater will not crank. i think its the coil
  • reyes_michae Sep 26, 2009
    its not a 15 inch its a 18 gas power 31ccryobi
    it makes a clicking sound
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Weed eater shut down once I began to trim
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jul 02, 2009
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
  • 150 Answers
SOURCE: one year old weed eater -- wont crank
if it was not winterized the gas may need to be replaced with new gas when gas sits it becomes old and moisture gets in it and oil can break down when its mixed with gas and sits around for months. of course follow the owners manual for starting procedure,if you started having problems with it at the end of last year it may be a combination of gas plugged fuel filter. I would start with new gas and oil.
Posted on May 13, 2011
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
How do i change a coil wire on a murray 2510 weed eater?
Murray Trimmer Product Support ' ManualsOnline.com
www.manualsonline.com/support/murray/trimmer/
Does Murray Weed Eater MS2550 use straight gas or. Murray ... HOW CAN I DOWNLOAD MURRAY 2510 TRIMMER MANUAL??? Murray Trimmer M2510.
Mar 13, 2015 | Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Does it make a big difference if i use a weed eater before applying round up?
Since Roundup works by being absorbed by the foliage and transported to the roots, I would think that cutting back the foliage would hinder this process, so you shouldn't use the weed eater before applying the Roundup.
Jul 27, 2011 | Roundup "" Weed & Grass Killer
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
