Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
10685 engine dies after starting.carb linkage is not moving
My son's 10685 will no continue to run after starting. I noticed when i engage the equipment control lever none of the carb linkage moves. thanks
    Problem Solver:
  • 13 Answers
See if you can move the parts on the carburater that are supposed to be controlled by the wire. Most likely they can turn, but it is the wire that is not working. The cable is 2 parts; an inner wire and and outer sleeve. Most likely there is rust on the inside. Sometimes you can soak the wire with a peneterant and work it loose. Best bet would be a new cable.
Posted on Oct 03, 2009
Governor,carb problem
Sounds like the linkage spring is not working correctly or was never replaced during rebuild. I would replace that spring as a starting point.
Aug 01, 2015 | Husqvarna Garden
My 5horse tecumseth snow blower stalls when I engage the auger,just rebuilt the carb
Make sure your engines governor linkage is moving freely. It is the linkage that the throttle goes to on the engine and then a lever from that linkage goes back to the carb. The throttle cable works through the governor to adjust to changing loads. Your linkage connections may be crossed limiting throttle opening as well. Look online for a throttle linkage photo and compare. Be careful and good luck!
Feb 15, 2015 | Garden
Woods 5140 dies when hydrostatic engaged
could be a seat switch issue. check the seat switch to be sure it is operating properly. mine became dislodged from its mounting position and would not work properly
Jun 04, 2014 | Woods Garden
John deere 111 dies when go to move it
I just got done with real similar prob my at first would start not rev up very well could drive it fine try to engage pto it die i checked everything carb back fire prevention was good cleaned carb seat switch checked out fine ignition switch had little corrosion changed it nope then it started to die after i started it and let out on foot pedal thought that was it checked with wires hooked up still get different readings each time unhooked switch it checked out fine then the seat switch would give me different readings on meter took it off test again fine was ready to have a fire sale on this pos i started to go through every electric con. Clean and make sure contact were good noticed a small crack on ignition switch female plug then found same on pto female plug got new plugs put wires in fixed everything
Jul 02, 2013 | Garden
Lawn boy 10685 starts but will not run
clean the carb there is dirt in the jets
May 03, 2012 | Garden
Starts runs strong and sputters and dies after it gets hot
Its very common that the carb will get clogged up with debris. If it is a newer unit the carb will be made of plastic. You have to use special cleaners or it will be destroyed. Carb cleaner will melt rubber and plastic.
Sea-foam is one product that I have had good luck with.
You May end up buying a new carb if you continue to have problems.
Apr 21, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
I have a 1982 Oldsmobile 4door Cutlass it has a 3.8 liter V-6 with a 2 bbl carb....the car is idling OK but when you step on the throttle it starts to run rough and very poorly...to keep it moving you have...
SOUND LIKE YOU MISSING THE IDLE SPEED SOLENOID.I REMEMBER I HAD A 81 OLDS 260 V8.IT HAD THE 2 BARREL ROCHESTER.IT HAD THE IDLE SPEED SOLENOID MAKING CONTACT TO THE THROTTLE LEVER.
Aug 11, 2009 | Oldsmobile Cutlass Cars & Trucks
Engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
Jul 04, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
337 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
